Question for those with H&R sways
Old Aug 6, 2003 | 06:57 PM
msindi's Avatar
I just got an e-mail from my tech saying the following:
"Your car is AWESOME, the suspension is just what the 996tt needs. The hieght is perfect the ride is superb and the handling is as it should be on a car like this. One small nuisance is the rear sway bar. It hits the frame crossmember when the vehicle extends. Not a big deal but makes a ****ty noise as a result. Contact supplier and see what you can find out. I'm assuming it is just made wrong because there is no way to correct this (clearance is less than 1mm!) I don't want to bend any thing until you talk to them. Call me at home this eve. if you get this or 1st thing in the morning at the shop. Car is al set otherwise and it takes only about 10 minutes to swap the sway bar out. Minor dissappointment is all, otherwise all went well."
Anyone else have a problem with rear sway??
Old Mar 14, 2004 | 12:35 AM
limitup's Avatar
limitup has a spectacular aura aboutlimitup has a spectacular aura about
Any follow-up to this, as I was just about to get me some H&R sways too. msindi, can you report back on this? Did you get it fixed or is it no big thing? Anyone else?
Old Mar 14, 2004 | 11:51 AM
msindi's Avatar
H&R is re-designing their sways as we speak...I got mine from AWE tuning (board sponsor - contact Mike there) and so as soon as they are available Mike said he will ship me a new one and will pay for shipping my old one back...That is service at its best!
Old Mar 14, 2004 | 11:57 AM
sharkster's Avatar
I had the H&Rs as well but Stephen and Kevin swapped it out for the GT3s... The H&Rs were much thicker but much heaver also and yes made all kinds of strange noises....
Old Mar 14, 2004 | 12:16 PM
limitup's Avatar
Any idea what the timeframe is on the new redesigned version?
Old Mar 14, 2004 | 01:17 PM
msindi's Avatar
again, not too sure but probably calling Mike will be your best bet...I think end of this month
Old Mar 14, 2004 | 05:34 PM
Turbo Ron's Avatar
Turbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to all
I was told March, now it has been moved to April. We will see what happens next month.
Old Mar 14, 2004 | 09:29 PM
calbobba996TT's Avatar
calbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the rough
I have been waiting for a redesigned version since june of last
year.
Boris
Old Mar 15, 2004 | 07:13 AM
Josh/AWE's Avatar
This whole deal is completely embarrassing. When I was in Germany in December I saw the new bars at H&R. However, I can't get an answer as to why I don't have them yet.
Here's an FYI. The reason that the bars make noise on some cars and not others is because during the production run the rear cross member was changed. The bars were designed for only one
style, but not other.
Once this was discovered, the bar was designed to work with both cross members.
I will continue to work on this. Thanks for your patience.
Jul 29, 2019 11:13 AM
away
Sep 4, 2015 12:30 PM
LiquidElephant
Aug 27, 2015 06:17 PM
