Boost reduction ?
Old Apr 7, 2007 | 10:02 AM
timf's Avatar
timf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud of
Boost reduction ?
Hi, I have a question and I think I know the answer but I'd like an opinion before I do anything :-)
I was driving to work this morning and everything was normal - I accelerated slightly, not much boost if any, and I felt a slight loss of power. It felt like a step function or as if I'd let off the gas abruptly.
Didn't think much of it as the engine was still a little cold.
A few miles further along when the engine was fully warmed up I went WoT and noticed the engine had lost it's 'punch'.
The boost which would normally come on hard at anything above 2500rpm was only managing to hit 0.5 Bar by about 4500rpm - normally it'd be approaching 1.0 Bar. Engine runs smooth as ever at higher RPM's - just takes longer to get there.
Engine runs fine otherwise, no check engine lights (at least not yet).
So I'm thinking an air leak somewhere - don't think it's the plugs or MAF.
Any thoughts or suggestions before I take a look ?
Any suggestions on how to find where the leak is - assuming there is one ?
FYI car is still under warranty, but has a few mods so might have to de-mod it if it turns out to be something serious.
Old Apr 7, 2007 | 10:06 AM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
I think your car went into limp mode. Disconnect the battery for a few minutes and it should reset. Make sure you have your radio/nav codes handy.
Old Apr 7, 2007 | 10:10 AM
LImp mode for sure. disconect the battery for 5 minutes...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Apr 7, 2007 | 10:17 AM
timf's Avatar
Good idea !
Hi Guys,
Wow that was fast and thanks for that tip - I'd forgotten all about 'limp mode'.
Certainly worth a try before delving in any further :-)
If it were a boost leak, I'm wondering what the symptons would be ?
No boost or very little boost at all ? Poor A/F ratio ?
I have an OBDII scanner / logger at home - I think I'll log a few vital parameters before performing a reset.
BTW even though it was in 'limp mode' sure wasn't slow - just didn't have that pin you in your seat feeling under WoT.
Felt a little like when I blew a head gasket on a 3.0CSL BMW I once owned a long long time ago now !
Thanks again - Tim
Old Apr 7, 2007 | 11:34 AM
dice996c4's Avatar
dice996c4 is infamous around these parts
Pardon my ignorance but what is a limp node ? When does it happen ?
Old Apr 7, 2007 | 02:15 PM
oak's Avatar
oak
wet noodle?
Old Apr 7, 2007 | 03:35 PM
timf's Avatar
Limp mode it was....
disconnected the battery for 5 mins and all is well again - back to 'warp' speed.
Seemed even faster than before !
Didn't have to re-enter any code in the radio / cd player.
Question now is why did it happen ?
I'll do an OBDII scan this evening to see if there were any codes set.
Thanks guys - I appreciate your help and advise.
Emre@Esmotor
Oct 19, 2015 12:06 PM
whtrabt
Oct 5, 2015 05:23 PM
Sales@RSW
Lamborghini
Oct 1, 2015 02:01 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
