Fender Issues
Old Apr 11, 2007 | 01:38 PM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Fender Issues
Ok I've spent the last 15 or 20 minutes using the Search, but I cannot find anyone who has had the same problem as I have.
My car is stock ride height with Cargraphic wheels on it. 245 up front 305's, both PS2's.
Almost any bump (even little sometimes) in the road at normal driving speeds causes the tires to smack the fenders. I've only had it happen 2 or 3 times at higher speed because it was on a freeway I dont know, but for the most part it happens real slow when Im going over certain train tracks, dips, etc. It is not rubbing on the inside of the fender at all. I've had the wheels off and everything. It hits the flat part of the actual fender and digs into the tire. Is there anything I can do, other then roll the fenders to fix?
It seems like everyone else with these wheels, or sizes has to roll their fenders unless the car is dropped.
Old Apr 11, 2007 | 02:04 PM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
align the car. soemthing sounds off. if the alignment specs show your rear camber to positive make sure they put them in spec(-1.0) or a bit negative(-1.5). You should be fine. Its close but shouldnt hit. my two cents
Suman
Old Apr 11, 2007 | 07:06 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
I agree w/the last post but.....you sure you are at 'stock ride height'?......the pic in your avatar doesn't look it.
Original equip ride height is so high, any wheel or offset will work (not look good, but 'work').
Old Apr 11, 2007 | 07:10 PM
Powell's Avatar
Not the best picture, but to me it does not seem low at all, but I see low as the fender almost touching the front tire (like on my brother Vette).
If it is lowered though it would explain some of the problem with the fenders. I know the wheels couldn't be a wrong offset. I think I'm going to have it lazer aligned anyway to see if I can prevent any further smacking of the fender lol.
Old Apr 11, 2007 | 07:29 PM
GreggT's Avatar
That is not OE ride height.......at the very least you have different springs running there.
OE height gives you about 4 inches of 'off-road' clearance in the front and about 3 in the back......that's why it's 1st thing anyone changes.
A couple other observations.
Offset on the rears looks pretty low.
Rake (front to rear) appears to have rear lower than some might like. If you have adjustables (coil-overs) I'd suggest a differential front to back of about 10mm lower to the front (that's where X73 or ROW would have you)......and I'd assume who's doing it knows where to measure (nothing to do with your fenders or bumpers ).
Old Apr 11, 2007 | 09:44 PM
Powell's Avatar
Measured the car tonight after I washed it. The tires are ~25.5" tall on both front and back and its like ~27" from the ground to the top of the fender. I had the wheels off awhile back but payed no attention to the springs or anything. I know they are not coil overs though, although I wish they were lol
The springs are black so would that rule the H&Rs out?
If this is true then this does explain the rough ride compared to the other TT I had for a weekend and the fender smack
Old Apr 13, 2007 | 01:44 PM
Powell's Avatar
Going to take the car tomorrow to get aligned. I'm going to take my wheels off tonight in the rear to look at everything. It doesn't make much sense because everyone like rubs on the outside of the fenders. Mine actually hits the flat part of the fender and digs into the tire.
Can't find anyone who has had this problem. They are the normal Cargraphic Racing 19's.
I'm just stumped
Old Apr 13, 2007 | 03:09 PM
GrettW's Avatar
GrettW is infamous around these parts
It looks like you have a pretty aggressive offset in the front and rear...this could be your problem
Old Apr 13, 2007 | 03:28 PM
GreggT's Avatar
Originally Posted by Powell
...... everyone like rubs on the outside of the fenders. Mine actually hits the flat part of the fender and digs into the tire.
Offset was my 1st comment the other day.
OK..........not real sure were understanding where you are saying it hits.....but no matter, it's the fender, not the inside shroud. You may be aware, good 19" rubber is $500 a pop so you need to get this rectified.
What size are your wheels?........yes, they are 19s.....but what is their width & offset (both are far more important in this case than the 19). When you have them off tonight, look for an ET number stamped on the inside. I do not know Cargraphic but just pulled up their site................looks like they have a 26, 27, and 36 mm offset...the 26 is 11.5J anf the other 2 are 11J.
Well.........golly, I wouldn't have 26 or 27mm offset on a TT....but that's just me......see what they say on the inside.....I'm guessing this is 'part' of your problem.
Old Apr 13, 2007 | 05:31 PM
Powell's Avatar
Gregg I will let ya know tonight. Thank you so much for the help.
Yeah I don't want to buy a new set of tires PS2s are not cheap!!!!
Old Apr 14, 2007 | 12:58 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
245 seem a bit fat up front. Seems most peeps are running 235
Old Apr 14, 2007 | 02:16 AM
Zippy's Avatar
I've been using -1.4 camber all around. I have 245 fronts and 345 rears with minimal rubbing - my rear fenders are rolled.
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
cdrik915
New Member Introductions
May 14, 2019 11:15 AM
XLR82XS
Oct 5, 2015 07:02 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
