Car went pop
Old May 9, 2007 | 12:07 AM
Lounge Lizard's Avatar
Lounge Lizard is infamous around these parts
Car went pop
Ok the car has been stored for 6 weeks with on battery conditioner because it was not possible to use one at the time.
Used a jump pack totart the car although there was enough battery to run electrics.
Drove the car back home did about 7-8 miles at under 3000rpm to warm her up ok. Close to home thought i'd give her a good blast in 2nd, got to 5500rpm 2nd gear and she popped and the engine stalled, I managed to get her to the side of the road, pulled the ignition key and restarted, she started up ok but the CEL is on.
Sound familliar? Any help appreciated, she's going in to Protechnik tomorrow for a check up anyway.
Old May 9, 2007 | 12:11 AM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
MAF
Craig
Old May 9, 2007 | 12:13 AM
Thought so, bugger.
Old May 9, 2007 | 12:16 AM
you blew a lower hose near the intercooler.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 9, 2007 | 12:23 AM
Craig's Avatar
That is also possible. I did this once.
Craig
Old May 9, 2007 | 12:25 AM
Yep it happened to me too. as long as u dont have Antifreeze spewing that is a good sign. And if you do it still could just be the rubber hoses going around the axles.... $30 fix.
9.66
click to view
Old May 9, 2007 | 01:10 AM
Just checked the garage....no leak or drips so good sign there.
Gonna get it checked out in the morning.
Old May 9, 2007 | 01:24 AM
Craig's Avatar
Look under the car and see if an IC hose is lose and/or off.
Old May 9, 2007 | 01:29 AM
Rgr, will do in the morning.
Old May 9, 2007 | 01:36 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
That's a bad sign! You would have wanted it to pop a hose to know exactly what the problem was!
Hope you get it fixed quickly.
Old May 9, 2007 | 07:43 AM
Highhats's Avatar
Highhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to beholdHighhats is a splendid one to behold
hose def. Check the hose from the IC's top and bottom. Sounds like a top hose if you ehard the pop. GL happens all the time. Do you have EVO hoses yet. If not I would look into getting them.
Suman
Old May 9, 2007 | 09:48 AM
996twin_sc's Avatar
996twin_sc is infamous around these parts
Same thing happened to me....Just like everyone said, IC hose.
Old May 9, 2007 | 05:47 PM
Well it wasn't the MAF & it wasn't the intercooler hoses, CEL light went out when I started the car this morning, gingerly drove it in for a service/oil change and check.
3 codes were logged and basically they were software spikes. The car saw an overpower warning and a DME module failure (which it hasn't) all checked and ok including the MAF......Phew!
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
r_matt_6
Oct 8, 2015 06:07 PM
no1joey
Sep 2, 2015 12:32 AM
gulf gt
Aug 27, 2015 10:27 AM
