Plenum Install
Old May 29, 2007 | 05:16 PM
  #31
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Originally Posted by oak
oh yeah, I forgot fvd stuff is engineered perfectly.
lol, That's why someone has takin time out to construct something similar, that will work! I mean FVD have sold a **** load of these, even the great man himself Mark had one.
Old May 29, 2007 | 05:22 PM
  #32
oak's Avatar
oak
I dunno, I can see atleast a dozen possible problem areas with no stand offs. I have seen the hose dan is supplying with his kit. I have used this exact hose for other stuff and it is not the most pliable stuff. sourced it from mcmaster. but hey, I'm relying on who ever installs it and has some good info to rely on.
Old May 29, 2007 | 05:26 PM
  #33
What did you use the same hose on that gives you concerns?
Old May 29, 2007 | 05:38 PM
  #34
oak's Avatar
oak
some other applications not for intake but for lab use. extremely stiff wired semi smooth interior but not flush hard greyish beige hose. black reinforced interior material over the internal wire. dan had sent me pics and noticed it's the same or appears the same.
Old May 29, 2007 | 05:48 PM
  #35
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Guys, the intake itself needs no mounts. With it installed properly it will not go anywhere. If a mounting post was needed I surely would have attached one. The hose is very durable as I did plenty of research and time into getting the right stuff that will hold up. And no, it is not the same stuff you find at McMaster.
My point of making the kit was to get rid of the large fuel filter and make a plenum that smooth flowing with no restrictions.If anyone wants more info on this then they can PM me.
Old May 29, 2007 | 05:54 PM
  #36
oak's Avatar
oak
don, have you installed this on your own turbo? and are there any areas that is in contact with the firewall, engine or any areas thay may cause any issues? one of the reasons I ask is that the hose you use is much larger in diameter than the fvd hose. correct?
by the way you might want to check with mcmaster if you already haven't they might have better hose selections. it's the bible for mfgrs/engineers and designers.
Old May 29, 2007 | 05:59 PM
  #37
It seemed strong but flexible to me, It was all flex'd up in a box when sent, my only concerns was the heat, which Don cleared up
Old May 29, 2007 | 06:02 PM
  #38
oak's Avatar
oak
I'm sure they will hang for awhile. it's the long run that I was concerned with but hey if you aren't planning on keeping your turbo that long who cares?
  #39
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
Originally Posted by steve harris
put one on my car great hp gain ,but no more great dv noise(which i miss ) the woosh is gone!!! had to cut the old plumbing into three parts with the motor lowered... tight fit
. mine is rock solid no mounts needed yet
are you talking on the RSS?
Old May 29, 2007 | 06:05 PM
  #40
Some apllications use silicon hose like Gemballa (sure Craig has it) surely that would be at risk of heat also! I don't know, obviously there is heat around but how Hot!
Old May 29, 2007 | 06:09 PM
  #41
oak's Avatar
oak
I don't think heat would be much of the problem it's the possible abrading and possible impinging that would cause the hose to eventually fail.
Old May 29, 2007 | 06:26 PM
  #42
One thing I did notice a while back on a RUF plenum that it was covered with a fire proof (heat resistant) fabric tape, this might be worth doing just for some added protection.
Old May 29, 2007 | 06:27 PM
  #43
dgreen78's Avatar
Oak, yes I have my kit installed in my car and I was worried at first about impingment/ abrading issues but when I installed the hose in my car I saw no issues with any hang ups or sharp objects rubbing against the hose. The hose itself is VERY durable and will hold up just fine IMO. Dont think I would install it on my car if I had a second thought about it.
Old May 29, 2007 | 06:30 PM
  #44
I do agree, the hose looked thick enough and still had good flex.
Old May 29, 2007 | 07:02 PM
  #45
oak's Avatar
oak
thanks don, thanks for clarifying. curious, exactly how long have you had this installed? I'm sure you have done long term testing on the unit. the fittings look good.
