Can someone please explain to me what sway bars do???
Old Apr 6, 2004 | 03:47 PM
RacerX's Avatar
RacerX is infamous around these parts
i have a 01 turbo with stage 4gt and just put on pss9's us version...i am very happy with the handling and ride...i have them set at 4 all the way around if anything id consider trying what 3 feels like in front...anyhow what would the sway bars do for me or what would i notice....i do NOT track the car nor do i plan to....pls explain
thanks
Old Apr 6, 2004 | 04:01 PM
20C4S's Avatar
RacerX,
glad u're happy with it. i think u mean 3 in the back (while 4 in front). i don't suggest u to do 3/4. mine is 4/3 now.
Old Apr 6, 2004 | 04:11 PM
retsel75's Avatar
retsel75 is infamous around these parts
Sway bars
Actually the term should be "anti-sway bars". What they do is when cornering, lets say a right turn, the insde right wheel would tend to lift up. The sway bars force the inside wheel in a turn down to make better contact.
Old Apr 6, 2004 | 04:25 PM
john stephanus's Avatar
john stephanus is infamous around these parts
The anti-sway bars reduce body roll in general and by adjusting either the front or rear bar (presuming they are both adjustable) you can alter the relative roll stiffness of the one end of the car compared to the other. In a very general sense, making one end of the car have greater roll stiffness corresponds to less stick at that end and more stick at the other end. There are situations where this does not follow, but it is generally true. This is the first place to look generally when trying to adjust the handling balance of the car...presuming the alignment is correct to begin with.
Old Apr 6, 2004 | 08:35 PM
MJC123's Avatar
Senior Member
MJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud of
The shop is recommending I only replace the rear sway bar on my TT, and I understand that RUF only replaces the rear, what are the implications of a stiff rear and stock front sway bar? Does this result in the body "twisting" more?
Old Apr 6, 2004 | 08:59 PM
limitup's Avatar
limitup has a spectacular aura aboutlimitup has a spectacular aura about
Hey Matt, I'm planning on doing the same thing. Upgrading the rear only is a great idea, no problems. So what bar are you getting? GT3? Shoot me a PM - maybe Hans and John can do both of our cars lol.
Old Apr 6, 2004 | 09:37 PM
sharkster's Avatar
if you do get the fronts many of us have had issues with the drop links not working quite right and having to get custom ones
Old Apr 6, 2004 | 09:43 PM
limitup's Avatar
Anyone know what the difference is between the GT2 and GT3 bars? And why does TRG sell the rear "GT3 replica" bar for like $500 when it's only a few hundred at the dealer? I must be missing something ... are the oem GT2 and/or GT3 bars not adjustable or something??
Old Apr 6, 2004 | 10:48 PM
Z0RR0's Avatar
Z0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant futureZ0RR0 has a brilliant future
The way a sway bar works is that it doesn't allow for much travel difference between sides of the car (ever tried to bend a square with a diagonal? same principle).
Old Apr 6, 2004 | 11:04 PM
Zippy's Avatar
Re: Sway bars
I think this is a litle backwards:
When in a right turn, the suspension on the left side compresses and the right suspension decompresses. With an anti-sway-bar installed, the right side suspension will also compress in a right turn (not be pushed down). Thus the car remains flatter in a corner and response is increased. By stiffening the rear only you induce more oversteer and by stiffening the front only you will increase understeer.
Old Apr 7, 2004 | 07:56 AM
SteveH's Avatar
SteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud of
this will take out the factory dialed in understeer and make the car more neutral. Many people believe that understeer is safer than oversteer (i am not one of them), so take that into account if you are not an experienced driver. Also if you never push your car near the traction limit you will probably never notice the difference.
-Steve
Rguy
Apr 12, 2020 11:11 PM
Myclue
17
May 19, 2016 11:14 AM
cherplex
Oct 1, 2015 08:30 PM
bongnation
Sep 25, 2015 02:58 PM
jpik2003
Sep 10, 2015 05:18 PM
