Help! Not reaching full boost!!!
Old Jun 21, 2007 | 03:23 PM
KJM3's Avatar
KJM3 is infamous around these parts
Hi Guys,
My car has a GIAC ECU /w Bailey DV's and it doesn't seem to be boosting fully.
Normally my car boosts to 0.9-1.0 Bar. (0.9 Bar in lower gears, 1.0 bar under WOT in 6th gear).
After I got a boost leak, the dealer looked it over and found a loose intercooler hose which they re-attached. They said they checked all the other connections and didn't find any other leaks.
It seems that I only boost 0.8-0.9 Bar now vs. 0.9-1.0.
Is it my imagination? Could it be because of the hotter weather?
Does anyone have any suggestions on where else they could look? (Maybe it's a DV that's not seating properly? (is that even possible?)
Any help is appreciated!
Thanks,
KJ
Old Jun 21, 2007 | 03:26 PM
It well may be due to the hotter temps....
the only realy way to check a boost leak is to actually do a boost leak test....
visual inspection is not good enough....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 21, 2007 | 03:30 PM
kayman's Avatar
kayman is infamous around these parts
try driving the car at night when the temps are lower.. see if you notice any difference.
Old Jun 21, 2007 | 04:08 PM
wross996TT's Avatar
Dealer didn't flash it back to stock...I hope. Probably hot weather!
Old Jun 21, 2007 | 04:46 PM
KJM3's Avatar
I thought about that, but does 77 deg. weather with 40% humidity seem that bad?
- KJ
Old Jun 21, 2007 | 04:48 PM
KJM3's Avatar
Is that something the dealer can handle themselves? Or does it require something to be "rigged up"?
- KJ
wross996TT's Avatar
- KJ
Nope...not the the weather...
Old Jun 22, 2007 | 08:04 AM
KJM3's Avatar
How long should it take to run a full boost leak test?
Are all the "joints" where things would normally leak easy to access? Or is it like changing the plugs (i.e. a Pain in the ***)?
Thanks,
KJ
Old Jun 22, 2007 | 10:29 AM
KJM3's Avatar
So I disconnected the battery for 15 minutes and put it back on. The car drove fine and when I boosted, the power came on good and I hit 0.9-1.0 bar in 3rd gear easy. Then when I went to boost again, the car would only boost 0.4 bar which sounds like the dreaded "limp mode".
That being said, what could it be? I had this problem before, so I got the plugs changed and I still seem to be having this problem. Could it be the coil packs?
- KJ
Old Jun 22, 2007 | 11:06 AM
wross996TT's Avatar
Get the codes read so we can stop guessing.
Old Jun 22, 2007 | 11:20 AM
arr0gant's Avatar
arr0gant is infamous around these parts
How much boost are you supposed to get, stock?
Old Jun 22, 2007 | 11:33 AM
KJM3's Avatar
I got an appt. first thing on Monday with the dealer.
So far from searching, it could be bad coil packs (I JUST had the plugs and clutch changed so I don't think it's the plugs).
Another problem it might be is wastegate failure, or a loose hose on the wastegate.
Another problem (but less likely) is that one of my DV's has dirt in it which is keeping it open (thus lowering the boost I can achieve). However, since my car is going into limp mode, I don't think this is the case.
Either way, I hope the Porsche scan tool can find something (even though I'm not getting a Check Engine Light).
I'll keep you guys posted!
Thanks for all your help,
KJ
Old Jun 22, 2007 | 11:34 AM
ckphillips's Avatar
ckphillips is infamous around these parts
alot of conditions such as astomopheric pressure (altitude) and temp have alot to do with boost levels. Esp around here in cincinnati in the fall, get a 60 degree day with 0 humidity, gain a few extra psi.
if it gets more dramatic deffinatly take it back to the dealer and check for leaks again.
Old Jun 22, 2007 | 12:35 PM
wross996TT's Avatar
for K16s stock... 0.6-0.7, for K24s stock...0.8-0.9.
Old Jun 22, 2007 | 07:49 PM
banditlex's Avatar
banditlex is infamous around these parts
check your plugs too. chipped cars run rich and foul the plugs faster than stock. you may need to change them.
