Psm/abs Light
Old Jul 4, 2007 | 10:43 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Psm/abs Light
Down South France on holiday, weather is scorchio!
Popped out to shops in car, floored it and at about 50/60, it suddenly died for a quick second (like I was completely off the gas) then everythng was ok. Continued journey with ABS/PSM Light on thinking everything will be ok after I have done shopping, the light will go out when I restart (had this occasionally before!) when I restarted light was back on, car feels good, still boosting 1.2, so I returned home disconnected battery for 5min, reconnect and light comes back on with no movement whatsover (just turn key and let it idle)
Anyone have any idea?
Thanks Steven
Old Jul 4, 2007 | 10:47 AM
I think its the mAF....
run a a code reader...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 4, 2007 | 10:56 AM
Hey Mark, can you still boost 1.2 with a MAF failure?
Thanks Steven
Brought a spare with me just in case (knew it was hot weather done here)
Old Jul 4, 2007 | 10:58 AM
Was 38 degree today, nice and toastie!
Old Jul 4, 2007 | 11:08 AM
if u have one switch it... see what happens... do u have a way to reset the code???
9.66
click to view
Old Jul 4, 2007 | 11:12 AM
Can I just disconnect battery to clear code Mark?
I have a spare as these things seem to blow in hot conditions, will change over.
Old Jul 4, 2007 | 11:19 AM
Away to change right now, get back and let you know anyways, thanks
Old Jul 4, 2007 | 11:33 AM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
don't think maf as car would ****ty..... try cleaning your maf see what happens... getting full 1.2 can't be in limp mod.. you might pull the correct fuse and the put it back ..... must be a glutch if car is running fine... when my maf went south had no codes at all ..have an oil filter ?
Old Jul 4, 2007 | 01:09 PM
I thought that PSM ABS lights usually mean MAF... but who knows... run the codes...
9.66
click to view
Old Jul 4, 2007 | 01:14 PM
wross996TT's Avatar
Unfortunately PSM/ABS codes are a catch all for many problems. The original symptoms...like the car shut down (limp) and then the codes...followed usually by CEL is typical of MAF failure. And it will not "reset" with battery disconnect until the MAF is replaced (cleaning will not help this). However, what is unusual is that you are hitting 1.2 bar...usually the blown MAF will not let you get more than .6-.7 boost???? So as Mark suggests, get the codes read.
Old Jul 4, 2007 | 02:21 PM
Never had a chance to change it as I forgot to bring the Hex head tool (hole in it lol) drop into stealer down here for a loan (hopefully)
Wross, I just clocked a previous post of yours that mentioned you blew a maf but was still boosting 1.2, Is this the case?
Old Jul 4, 2007 | 09:38 PM
wross996TT's Avatar
No... when I blew my MAF (3 times) I was never able to get out of limp....6 boost. Not sure where you got that...
Old Jul 5, 2007 | 09:52 AM
kd126500's Avatar
kd126500 is infamous around these parts
Had the same issue just had it fixed
I had the same indicator lights come on and thought it was the MAF. The code would clear then appear each time I drove the car.
Took to Sharkwerks and they checked the codes. Turned out to be a faulty break switch. Part and labor was a 1/3 the costs of a new MAF. The failed part was a cheap plastic switch.
Old Jul 5, 2007 | 10:08 AM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
I drove across country (US) with a blown MAF - didn't impede my ability to boost on the gt700 kit.
- chuck
Old Jul 5, 2007 | 01:03 PM
It's maybe just the way you have worded it, I done a search for "blown maf" and it was under the heading "Symptoms of blown or going MAF" sorry if any confusion.
Anyway, it was a MAF, lucky I was carrying a spare, kind French chap changed it as I never had the hex tool with me!
Spot on again Mark +1 Rep point
