Tire peel just in the middle?
Old Apr 22, 2004 | 06:57 PM
ypshan's Avatar
ypshan is infamous around these parts
Angry Tire peel just in the middle?
Just finished a day of Skip Barber school with half a day of hot laps and some autocross.
My two front P Zeros look like someone just unevenly peeled a layer of rubber off the center ridges. The peel only happened to the two center ridges. The rest of the tires and the back tires are fine.
I started the day with 36 psi in front.
Not sure what happened. Anybody experienced the same or can explain?
Old Apr 22, 2004 | 07:53 PM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
You scrubbed off some rubber, you could have dropped your pressures down, while driving aggressively at events your tires will build up heat and your pressures will increase, keep that in mind.
keoni1978's Avatar
keoni1978 is infamous around these parts
maybe too much air in your tires!?!?
Old Apr 22, 2004 | 08:03 PM
ColorChange's Avatar
ColorChange is infamous around these parts
I agree, sounds like you were too high pressure. Normally, 32 cold is a good starting point as most tires are best around 40 psi hot. This would be typical at the track, 8-12 psi increase. If you were overinflated, the centers would get the hottest, and you would wear them quickly there.
Old Apr 22, 2004 | 08:07 PM
ypshan's Avatar
Funny thing is I had run the same tire pressure before in the middle of a hot summer with no problem. Also the rear tires started at 44 psi cold so should have much higher pressure but still fine.
I did slide more today. What pressure should I use?
40 psi hot for all four?
Old Apr 22, 2004 | 08:16 PM
44 cold? Wow!!! Way high!
Yes, as a good rule of thumb, 40 psi hot is how tires are typically designed to run for heavy cars like ours. I am surprised you weren't sliding around like hell with pressures that high?
To really know what you are doing, you should get a insertion tire pyrometer (tire thermometer). Here is the best one I know of and the one I have.
http://www.longacreracing.com/catalo...id=188&catid=7
You have to make sure you measure as hot as possible, but this will tell you how you are running. I'll bet that you were at least 20F higher in the centers, probably 30 or more, and this would have told you to drop pressure.
Old Apr 22, 2004 | 08:25 PM
Zippy's Avatar
Hey Color:
That's a serious looking unit!
Mike
Old Apr 22, 2004 | 08:30 PM
I'm an engineer and just love tech toys! The thing even has predictive temperature compensation so you don't need to wait for full temp readings to stabilize. It is fast accurate, and awesome.
PV=nRT.
Sep 9, 2022 06:06 PM
danyoP4S
Sep 30, 2021 05:06 AM
WheelB
991 Turbo Vendor Classifieds
Jul 23, 2018 09:37 PM
speedyizzy
Lamborghini
Sep 9, 2015 06:05 PM
speedyizzy
Ferrari
Sep 1, 2015 05:57 PM
