32hp and 22ftlbs Gained - My New Project
We just dynoed the X50 doing a before an after install with our Intake Kit. The car is equipped with the Agency Power Exhaust, Boost Hoses, Forge Diverter Valves, and Upsolute ECU upgrade (only running 1.1 which I thought was low.) But you can see a good difference!
He is running only 1.1 bar. Needs more juice. But that was Upsolute flash. We will send it back. Also the tune was richin up for the intake. So you can see when the intake was added, the HP gain. Does not matter the baseline, all we are looking at is the before and after.
His Torque is there which is the biggest improvement from the intake as well as that INSTANT thrust you feel. So... that jumped up. His HP is probably around 30 lower then normal.
I have been running the stock airbox with the temperature couplers around town. No difference. Temperature is temperature whether it is the aluminum or plastic. Same couple degree difference in all driving conditions. Just a FYI
so when do we expect to see these at our doorsteps? haha
cant wait regardless...mo power isnt a bad thing to wait for...
Post some feedback when you get it on the power or performance gains. driving around with my stock box sucks. i can TOTALLY telll the difference. Much less responsive.
See! Thats why I could not wait. I didn't want to go back to the stock one.
I cant wait to get mine either...
