Trick to adding air to rear tires with 19-inch wheels?
Old Sep 19, 2007 | 11:17 AM
emissary's Avatar
emissary is infamous around these parts
All,
I recently purchased and installed a set of 19-inch iForged Monaco wheels on my 996 TT. When I went to perform my weekly (er...monthly) tire pressure check, I discovered a bit of a problem. While I'm able to access the front valve stems just fine (I can check tire pressure and attach an air hose), the rear valve stems are significantly recessed. I tried four different tire pressure guages and two different air hose attachments; I couldn't get a single one to attach. Is there a trick to doing this, or do I need different tools? Any assistance would be most appreciated.
Here's a picture of the rear wheel valve stem:
Old Sep 19, 2007 | 11:21 AM
wross996TT's Avatar
I had a similar problem with my HREs...they provided a valve stem extender that screwed onto the valve stem...
Old Sep 19, 2007 | 12:18 PM
maxwell's Avatar
maxwell is a jewel in the roughmaxwell is a jewel in the roughmaxwell is a jewel in the rough
they should have used longer valve stems. Mine stick out about 1/2 inch.
Old Sep 19, 2007 | 01:35 PM
emissary's Avatar
Do you think this is a specialty item, or can I purchase something like this at an auto-supply store?
Old Sep 19, 2007 | 05:58 PM
wross996TT's Avatar
Call HRE and see what they have...I'll look around as well.
Old Sep 19, 2007 | 06:00 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
I have gotten a set from NAPA, your mileage may vary though, very handy at work when seeing many different types of wheels. I think it came in a 4 pack.
Old Sep 19, 2007 | 07:56 PM
Dirty Mac's Avatar
Dirty Mac is infamous around these parts
You can get valve extenders at pretty much every auto part store.
By the way, I discovered a trick to make locating the valve much easier on wheels like ours. Ask whoever is installing your wheels onto your car to adjust the center cap logo to point to the valve. My center cap is the Porsche logo so I have the bottom of the sheild pointing to valve. A huge help on track days where I am constantly checking my pressure
Old Sep 19, 2007 | 08:29 PM
Zuma 911's Avatar
Zuma 911 has a spectacular aura aboutZuma 911 has a spectacular aura about
The Schrader valve looks bent to me from your photo. Check if it is centered. Good Luck.
Old May 28, 2008 | 10:22 PM
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
Valve extenders at any tire store, they even give them away for free
Old May 28, 2008 | 10:42 PM
jimq's Avatar
jimq is infamous around these parts
I have seen them at Walmart also.
Old May 28, 2008 | 11:10 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
You need something like this, but only have them attached when pumping air...
http://cgi.ebay.com/ebaymotors/RV-DU...spagenameZWDVW
Old May 29, 2008 | 11:43 AM
roadsterdoc's Avatar
Member
roadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to beholdroadsterdoc is a splendid one to behold
Like others have said, valve extenders are available from any automotive store or truck stop. Just be sure to remove it when you are done checking the pressure as 1) they tend to leak air and 2) they weigh as much as a small wheel weight so they can throw off the balance.
Old May 29, 2008 | 12:14 PM
mannytt's Avatar
mannytt is infamous around these partsmannytt is infamous around these parts
I got mine from Kragen
Old May 29, 2008 | 08:08 PM
lsbe36's Avatar
lsbe36 is infamous around these parts
Sears or call Hre
Old Jun 10, 2008 | 10:30 PM
Green Turbo's Avatar
Green Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to behold
you can buy extensions at pep boys
COBB Tuning
Jan 1, 2025 09:02 AM
COBB Tuning
Nov 9, 2015 08:02 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
no1joey
Sep 2, 2015 12:32 AM
ModBargains
Aug 20, 2015 12:28 PM
