Help, having trouble installing sports seats...
Old Nov 15, 2007 | 01:50 PM
lilstan's Avatar
lilstan is infamous around these parts
OK, I got my sports seat the other day and now I'm trying to install them but I ran into a problem. For some reason, the rails on the sports seats aren't lined up with each either, (left and right). Since that's the case, I'm not able to bolt down both rails. Does this happen with everyone? What do I do? I took a quick glance and it doesn't seem like I could change the rails. Can anybody help?
Old Nov 15, 2007 | 02:20 PM
jstgermaine's Avatar
jstgermaine is infamous around these parts
What do you mean by "not lining up"?
Are we talking the width between the rails, one rail longer than the other, the rail bolt holes don't line up with those in the floor, etc?
Old Nov 15, 2007 | 05:39 PM
lilstan's Avatar
Here are the problems I'm having:
One rail is longer than the other.
Rail holes don't line up.
The rails on the door side (where the seat controls are) line up good, but the rails on the other side (center console) don't line up at all. I don't know if it's becuase the seats came out of a GT3 or what. Does it make a difference if the seats came out from a GT3 or the C2, C4, or turbo?
Old Nov 15, 2007 | 06:07 PM
Redridge's Avatar
It seems that the rails are out of sync, pull the adjustment bar and move one of the rail to line up with the other... you might need two people for this since it is spring loaded...
Old Nov 15, 2007 | 06:10 PM
lilstan's Avatar
There's an adjustment bar? Are you talking about the handle the moves the seat back and forth or is there a bar the adjusts the actual rails?
Old Nov 15, 2007 | 06:11 PM
sklarge's Avatar
sklarge is infamous around these parts
the adjustment bar should be the only thing connecting the two rails. so once you remove that, it should be fairly easy to line up? unless they're completely bent sideways or something.
i dont know i've never seen a gt3 seat before, but that's my general consensus on seat rails.
Old Nov 15, 2007 | 07:04 PM
Redridge's Avatar
Yes, adjustment to go back and forth, the rails move independently from each other, one of the rails must of moved accidently while you were pulling on the adjustment handle... BTW, I have gt3 seats and it will fit in any 996 with no issues.
Old Nov 15, 2007 | 07:06 PM
GT3 Chuck's Avatar
Administrator
Redridge is correct...make sure the adjuster is in the same hole from front on both rails...it is easy to get one out of sync when the seats are out of the car
Old Nov 15, 2007 | 07:19 PM
lilstan's Avatar
ok, i just got home and I moved the rail just like Redridge suggested. Since it's dark and my garage is clutered with hella s!@t, I'll try that again tomorrow morning. I think I got it though. Thanks for all of your help. I will post the outcome and maybe some pics tomorrow. THANKS AGAIN!!!
Old Nov 16, 2007 | 04:03 PM
lilstan's Avatar
Ok, I got the seats to line up. Now I'm having trouble with the wiring. DAMN!!! Any suggestions?
Old Nov 16, 2007 | 09:49 PM
oak's Avatar
oak
hey lilstan, look up board member adam bowles he just installed my old set of sport seats. he did mention that he had to make some type of wiring modification. from what I remember it was just a pin relocation.
by the way are you looking for rear seats to match the sport seats? I have a set of pristine reat seats never sat in. they are carbon or what some call black leather.
Old Nov 16, 2007 | 09:50 PM
Redridge's Avatar
whatever you do, do not turn the key on, or your airbag light will turn on...and will need to get it reset by dealer.... you might need to put the old one back in and retrace the steps you took.... damn man, stop working in the dark, put up some high wattage bulb and clean up that garage!... get organized!
Old Nov 17, 2007 | 06:37 PM
lilstan's Avatar
I just got them in and I love the way they feel. Thanks for all the help guys!
MadWhip
Sep 3, 2015 02:04 PM
PelicanParts.com
Aug 21, 2015 01:37 PM
Regent
Aug 21, 2015 11:14 AM
ppwchiang
Aug 20, 2015 10:28 AM
