how to change the oil seperator
Old Jul 8, 2010 | 08:10 AM
  #31
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Well, my guy finally got the AOS done. What a PITA. Being a TIP, he dropped the tranny. As soon as that was out, it didn't take too long. The only additional thing that was done was rerouting the wires. The cam sensor wires are right below the AOS. I've been getting the p1531 code on and off for 2-3 weeks. The coolant and oil from the AOS was dripping on the wires triggering P1531 in my case. Check the RMS also.
Old Apr 2, 2019 | 12:36 PM
  #32
WaddyP's Avatar
WaddyP is infamous around these parts
Thanks for all the info. I am about to replace mine on a 2000 C2 manual. I am going to drop the transmission and do it from there, it seems much easier than from above. I will also do a clutch job. I have a LN IMS so I am not touching that.
My question is: how much coolant fluid comes out of the lines when you disconnect them? Since I'll be under the car should I be prepared to get soaked?
Old Apr 4, 2019 | 02:23 PM
  #33
lavitzlegend's Avatar
lavitzlegend is infamous around these parts
As long as you're prepared to poke something in the end quick or kink the line with a zip tie or something it shouldn't be too bad. Just don't forget to undo it before you put it back together!
Old Apr 4, 2019 | 03:17 PM
  #34
WaddyP's Avatar
Great, thanks.
alwaysbored786
Apr 19, 2016 05:51 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
