Remote doesn't unlock the doors - HELP!
Old Jan 28, 2008 | 04:22 PM
John Romano's Avatar
John Romano is infamous around these parts
I hope someone can help me here....
The remote on my key does not open the doors or the trunk. Central locking does work on the dash switch, but only after the car is started. After using the key in the door lock to unlock the door I have about 5 seconds to get the key in the ignition and turn it before the alarm starts honking. The unlock switch in the dash does not always unlock the passenger door, and the gas cap door is completely not working; I have to use the little pull wire inside the passenger door jamb.
I have replaced the battery in the key and replaced both fuses that have anything to do with central locking or the alarm. Still not working.
My next guess would be that the receiver isn't working? But at this point I'm lost. Anyone ever had this problem?
Electrical gremlins seem to live in my car. Last year I had to replace the alternator shortly after I replaced the battery. Then the ignition switch had to be replaced. A couple of months ago the air bag light went on. That was traced to the faulty ground/seat belt buckle deal. Now the remote.
Any words of wisdom, comfort. commiseration?
Thanks!
Old Jan 28, 2008 | 06:14 PM
tistrada's Avatar
tistrada is infamous around these parts
This happened to me before. I had to reset my remote. This may sound funny but it worked for me. Open up your remote, take the battery out, flip it upside down and reinsert it into the remote for at least 10 seconds. That should reset your remote back to default. Flip the battery back to right side up and insert it back into the remote. It should work now. Hope this helped, it worked for me.
Old Jan 28, 2008 | 06:43 PM
wross996TT's Avatar
First question is what car/year? Then...did you leave the car unused for over 5-6 days? If so your remote went to sleep...simply open with mechanical key and within 5 seconds hit the open door on the remote. If that does not work, try the above ^ procedure. If that does not do it, your remote may have failed and need to be re-programmed by the stealer.
Old Jan 28, 2008 | 09:11 PM
Thanks guys. Year and model are in my signature. The car was not idle for 5-6 days. I did both procedures as described and the remote still does not work. Grrrrrrrr........ What is involved in stealer reprograming and what can I expect to hemorrhage for it?
Thanks again!
Old Jan 28, 2008 | 09:26 PM
djantlive's Avatar
time to visit the dealer if you tried the reset method that tistrata described. cost to replace the electronics in the key and reset key is about $250-350 I think.
Old Jan 28, 2008 | 09:51 PM
wross996TT's Avatar
Originally Posted by John Romano
Thanks guys. Year and model are in my signature!
Sorry, I have the show sig turned off
Perhaps you can find an independent with PST2 or PIWIS to do it for less.
Old Jan 28, 2008 | 11:44 PM
fastoc996twint's Avatar
fastoc996twint is infamous around these parts
who in socal has the pst2 or piwis????????
Old Jan 29, 2008 | 06:04 AM
zdr2k's Avatar
zdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud of
all german auto - escondido ca. they may be close to what the dealer charges for labor though. sunset or suncoast should both get a key head for about 130.
g.l
Old Jan 29, 2008 | 08:31 AM
So, is it a new key head I need? And then have it programed for my car? Will this work?
Thanks!
Old Jan 29, 2008 | 08:47 AM
zdr2k's Avatar
Thanks!
Sale on at Suncoast Por.
http://e-partssales.com/Merchant2/me...Code=POTE996CM
will need programming from dealer/indy.
jorge
Old Jan 29, 2008 | 08:48 AM
zdr2k's Avatar
my bad, that's just the head, does not include electronics.
Old Jan 29, 2008 | 08:51 AM
zdr2k's Avatar
NC 996TT
Mar 23, 2023 06:19 AM
Rguy
Apr 12, 2020 11:11 PM
NIKAS
Aug 20, 2019 07:53 PM
lokmeup
Sep 9, 2015 09:24 PM
