996 Engine Noise
Old Jul 6, 2004 | 11:22 PM
BIGDEE's Avatar
BIGDEE is infamous around these parts
996 Engine Noise
I HAVE A ENGINE NOISE THAT SOUNDS LIKE A WILD BOAR WHEN STARTING MY CAR. IT HAPPENS ONLY ON OCCASION,AND ONLY APON INITIAL STARTUP,THAN GOES AWAY AND MIGHT NOT COME BACK FOR 3 WEEKS.ANYONE HEARD OF THIS NOISE
SORRY GUYS TO BE MORE DESCRPTIVE THINK ABOUT STEPPING ON A PIGS FOOT , THAT TYPE OF DEEP SQUEEL. THANKS FOR RESPONDING I WAS LAUGHING LIKE CRAZY BECAUSE I DONT THINK I EVEN EVER HEARD A WILD BOAR
Old Jul 7, 2004 | 12:32 AM
RobynC's Avatar
Porsche Chick
RobynC is infamous around these partsRobynC is infamous around these parts
I can't say that I have ever heard a wild boar before to know what that sounds like. However, could it possibly be your exhaust? A leak? Things quiet down once the valves open after initial start up. (I think that is right)
A few things to ensure... AC is off, so to rule out the compressor being the culprit of such a sound. You have checked your oil level? I'm just throwing out ideas.
Old Jul 7, 2004 | 03:31 AM
newport996's Avatar
newport996 is infamous around these partsnewport996 is infamous around these parts
I'm with Robyn...What the hell does a wild boar sound like? Please be a little more descriptive. Is it a howl? A grunt? Whine?
Old Jul 7, 2004 | 07:07 AM
spr's Avatar
spr
spr is infamous around these parts
sounds like a bad tappet that is a somewhat known issue, not pumping up etc.
Old Jul 8, 2004 | 02:57 AM
harvs's Avatar
harvs is infamous around these parts
Unhappy i think i have the same noise
happens on cold startups, car screaches like a boar for like half a second, it's kinda embarassing. I haven't figured it out, but it sounds like a belt slips loose and the gears spinning too fast
OR
it also sounds like maybe the bearings somewear are loose and/or worn, but immediately smooth out after a second or so. For example, back when you were a kid if you ever had a big toy car, and you spun the wheels with your hand, it would spin normally, but if you spin it too fast, it would make a loud noise, cause vibration, and slow down
anyways, let me know if you figure it out, so i can get it fixed too
Old Jul 8, 2004 | 05:52 AM
spr's Avatar
spr
is it a tapping sound that goes away or if it's the screach then it could be the belt. I had to replace mine as it shredded aka broke at 30k.
Old Jul 8, 2004 | 06:21 AM
shane's Avatar
shane is infamous around these parts
check your flywheel...it might have some damaged teeth....that will make the starter slip and make a loud noise .
Old Jul 8, 2004 | 10:01 PM
greenman's Avatar
greenman is infamous around these parts
Had a similar problem it was the fan. It would make a intermittent squealing sound. Took a couple of hours to fix.
tropicatango
Jun 8, 2025 01:00 PM
tzeseong
Aug 17, 2024 11:08 AM
carwash
Sep 29, 2015 10:43 PM
New991S
Aug 31, 2015 05:22 PM
Zero911
Aug 24, 2015 06:51 PM
