Key Stuck In Ignition.
Old Jun 29, 2008 | 07:42 PM
JW996's Avatar
JW996 has a spectacular aura aboutJW996 has a spectacular aura aboutJW996 has a spectacular aura about
Valet Guy Somehow Bent Key In Ignition And Now Air Con,wipers, Don't Work And Key Won't Come Out. Anyone Have Experience With Bent Key In Ignition. Thanks. Jw
Old Jun 29, 2008 | 07:48 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Look at the thickiness of the key, I doubt it could be bent. Probably a problem with the tumbler mechanism and the ignition switch. The switches are known to go bad fairly often. You can find them on Ebay for $20 or so. Good luck
Old Jun 29, 2008 | 08:58 PM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
shake the wheel back and forth while you pull it
Old Jun 29, 2008 | 09:41 PM
daytrader's Avatar
daytrader is infamous around these parts
Also, there is a mechanical **** within, if the ignition switch goes bad it won't release the ****.
Old Jun 29, 2008 | 10:02 PM
hot996's Avatar
hot996 is infamous around these parts
My key would jam every now and then. I replaced the switch in the back, and it's as good as new. Here's a couple of links to the DIY:
http://www.renntech.org/forums/index...howtopic=16077
http://www.renntech.org/forums/index...e=post&id=6617
I got my switch on eBay for ~$20
Old Jun 29, 2008 | 10:12 PM
EB847's Avatar
EB847 is a jewel in the roughEB847 is a jewel in the roughEB847 is a jewel in the rough
mine got stuck, dealer knew right away what it was over the phone (common problem). a plastic piece inside the ignition switch breaks. cost of fix was $550 (covered under cpo warranty). the service manager told me to force the key into the start postition (hard to do), then back it off to the run position (so the starter doesn't keep running) to get it moving. it worked. i have an 02 carrera.
Old Oct 7, 2008 | 07:03 PM
Merlin's Avatar
Merlin is a glorious beacon of lightMerlin is a glorious beacon of lightMerlin is a glorious beacon of lightMerlin is a glorious beacon of lightMerlin is a glorious beacon of lightMerlin is a glorious beacon of light
Anybody got a part # on this particular issue? And also do I need more that 1 part?
Old Oct 8, 2008 | 04:16 PM
Redridge's Avatar
same exact failure... but I can still wiggle the key out... replace the ignition switch behind the dash... you will need a set of small jewelry/electronics screw driver from radio shack.
Old Oct 8, 2008 | 10:44 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
Would have to check with your parts department there is a year break on if you need more then just the switch, you may need the whole cylinder with the column lock, (looks like an aluminum gun) then you would have to swap the key cylinder into the new unit, if you can get just the switch it is held in with two set screws covered in red tamper paint, just scratch the paint away and back the screws out.
Old Oct 9, 2008 | 01:39 PM
NIKAS's Avatar
NIKAS is infamous around these parts
You may need a new ignition switch. You might be able to still operate car/wipers/radio if you giggle wheel and manually click back the key to the left one notch after ignition. That's how I'm getting around now. I'm about to install my 3rd replacement switch. Part is shared with Audi and avail from those dealers. Part no. 4A0905849B, around $45. There is a DIY on Renntech which requires Porsche tool, or one that others have designed that works. Porsche dealer may or may not sell you just the switch - they like to replace the entire ignition system, which is $$$$.
Old Oct 22, 2008 | 08:12 PM
Porsche917's Avatar
The only non standard "tool" I can think of for replacing the ignition switch is a paper clip to get the lock out of the old cylinder.
Bmw M3 Guy
Feb 21, 2018 09:29 AM
Stormdog
Sep 26, 2015 03:18 PM
allroadusa
Sep 25, 2015 10:57 PM
kensilver
Sep 17, 2015 04:03 PM
lokmeup
Sep 9, 2015 09:24 PM
