PSS10 Problem, fronts won't adjust???
Old Aug 17, 2008 | 11:19 AM
RocC4S's Avatar
RocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant future
Just had new PSS10's installed. Front dampers wont adjust, gets to a point after a clockwise turn then just stops. I tried with the car jacked up and sitting on the ground. Rears are just fine, clicked into each detent.
Anybody heard of this or had similar problem that can be resolved easily?
Thanks,
Roc
Old Aug 17, 2008 | 12:27 PM
'ringmeister's Avatar
'ringmeister is infamous around these parts
wish i could help, but curious as to the diff between pss9 & pss10? thanks
Old Aug 17, 2008 | 12:36 PM
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
pss9 have 9 settings, pss10 have 10 settings. sounds to me like you should give Bilstein a call, they are usually very helpful.
Old Aug 18, 2008 | 10:22 AM
pmkazz's Avatar
pmkazz is infamous around these partspmkazz is infamous around these parts
It sounds like the nut below the adjuster is a little tight causing the adjustment wheel to bind. You can lossen the nut slightly.
Old Aug 18, 2008 | 02:19 PM
RocC4S's Avatar
Thank you!
I'll try that.
Old Aug 18, 2008 | 07:07 PM
RocC4S's Avatar
Didn't help unfortunately.
In contact with Bilstein, they still don't know what could be wrong either.
Old Aug 20, 2008 | 08:22 AM
RocC4S's Avatar
Update:
Spoke with Bilstein. I now have to have both fronts removed and sent to them for inspection as to why they don't adjust.
Old Aug 20, 2008 | 12:05 PM
Redridge's Avatar
that sux!.... I take it, it wont adjust even it is off the car?
Old Aug 20, 2008 | 08:49 PM
mathism's Avatar
mathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond repute
I've got 10's and have had no problems. There is a stop at either end of the adjustment range. So, if you turn all the way to 10, it will stop and not go any further. Same down to 1. Is your dial locked in place and won't turn at all?
Old Aug 21, 2008 | 07:34 AM
RocC4S's Avatar
The best analogy I can give is that it feels like screwing in a lug bolt, no detents. You can unscrew it all the way out until the adjustment **** comes out in your hand along with the push rod that sits inside the damper. When you put it back in I get about 3 full rotations on the **** until it hits the stop pin. Frustrating huh?
Old Aug 21, 2008 | 08:37 AM
mathism's Avatar
Quite odd. Sounds like the adjustment **** isn't linking up with whatever it should to click thru the settings. Bilstein should warranty that for you.
Old Aug 21, 2008 | 08:42 AM
RocC4S's Avatar
Yeah, I hope so. The bummer is that it has to come back apart, wait for the repair, and then re-install/align.
Saw you may be at the DE at Blackhawk in Sept., may see you there if the car is ready....
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
gulf gt
Aug 27, 2015 10:27 AM
TrackOne
Aug 20, 2015 12:56 PM
