Audio Question?
Old Aug 19, 2004 | 04:08 AM
Kaltex's Avatar
Kaltex is infamous around these parts
Question Audio Question?
Hello all,
I had a quick question, I bought the kenwood ddx7015 and was wondering if it would work in my 02 carrera cab. with the bose stereo system. If so, what all is required for the installation?
Thanks Kal
Old Aug 19, 2004 | 07:18 AM
yellowbmr's Avatar
yellowbmr is just really niceyellowbmr is just really niceyellowbmr is just really niceyellowbmr is just really niceyellowbmr is just really nice
shouldn't you have checked before purchasing?
i am not a kenwood man, so i let others speak.
Old Aug 19, 2004 | 07:38 AM
996garage's Avatar
996garage is infamous around these parts996garage is infamous around these parts
I'm not 100% sure about the 996, but Bose systems typically have powered speakers that are integrated with the Bose headunits. Therefore you cannot interchange different brands of speakers or headunits.
However there are converter boxes that you can install that will bypass this limitation and allow you to use a different headunits with the bose speakers or vice versa.
Old Aug 19, 2004 | 09:14 AM
newport996's Avatar
newport996 is infamous around these partsnewport996 is infamous around these parts
is that the MOST digital bus system? I bought the same reciever and NAV system...great unit. If your car has the digital system then no, you will need new amps, if not then yes, just connect the system to your previous input wires and you are all set...What CD player was there before? The CDR-23? if so thats digital, if it's the CDR-220 then you can simply use the same wires to connect your system.
Old Aug 19, 2004 | 10:20 AM
Kaltex's Avatar
Its the crd 220 with the bose speakers and amps? Is there any additional parts I need to buy? Im trying to keep the bose speakers and amp and use the kenwood for the headunit.
Old Aug 19, 2004 | 10:56 AM
newport996's Avatar
nope, all you need to do is connect the outs to the ins and thats it.
Old Aug 19, 2004 | 11:07 AM
Kaltex's Avatar
That all for the help i greatly appreciate it.
cnebrask
Oct 3, 2024 08:19 PM
Money2536
Jan 19, 2022 08:22 AM
RallyBird
Oct 7, 2015 01:20 PM
terminal_ac
Sep 12, 2015 03:26 PM
ppwchiang
Aug 20, 2015 10:28 AM
