has anyone upgraded their brakes on the 996?
Old Oct 26, 2004 | 12:19 PM
LIL RAJA's Avatar
LIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant future
if so what brand and what size rotors?
Please advise.
Raja
Old Oct 26, 2004 | 01:56 PM
RWDRIFTC2's Avatar
RWDRIFTC2 is infamous around these parts
I have the Stoptech 14" Front Kit, and 13" Rear Kit with cross drilled rotors on my 996 C2
Old Oct 27, 2004 | 01:06 AM
1317wholesale's Avatar
1317wholesale is a glorious beacon of light1317wholesale is a glorious beacon of light1317wholesale is a glorious beacon of light1317wholesale is a glorious beacon of light1317wholesale is a glorious beacon of light
Brembo 15' for front and 14' for for rear in red with white "Porsche" lettering
Old Oct 27, 2004 | 01:08 AM
mooty's Avatar
mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !
no need to upgrade brk on 996c2. just put pagid's on and you have way more brakes than you will ever need.
Old Oct 27, 2004 | 02:03 AM
Don Relentless's Avatar
Don Relentless is infamous around these parts
i agree with mooty, stock brakes are good enough with the power on a NA 996. the only time i have experienced brake mush is doing the malibu canyons back and forth under very harsh driving. as malibu has a very steep grade. even during track events the brakes are fine. just get sticky tires.
Old Oct 27, 2004 | 02:22 AM
TT Surgeon's Avatar
The stock breaks are plenty, as Eric and Mooty said. The only thing you might need if you track your car is an extra set of pads.
Old Oct 27, 2004 | 04:48 AM
daily996's Avatar
daily996 is infamous around these parts
pagid's brake pads, which colour is for street and track use? or only one colour " orange "
Old Oct 27, 2004 | 01:22 PM
mooty's Avatar
some prefer pagid yellow RS-19's. i use pagid orange RS4-4 for track and street. they don't squeak on my 996 at all. but they are a bit harsh on the rotors. there are other colors that are more suited for pure street driving, however, i am not familiar with them. check out pagid's web site. they have description of all the different pad compounds and respective uses.
Old Oct 28, 2004 | 03:10 AM
LIL RAJA's Avatar
can anyone post a pix please?
thanks
Old Oct 29, 2004 | 12:35 AM
spr's Avatar
spr
spr is infamous around these parts
why? they're just pads- they all look the same other than the compound and color of backing plate, unless you're talking about aftermarket kits aforementioned.
Old Oct 29, 2004 | 01:11 AM
Porsche Babe's Avatar
Moderatorette
Porsche Babe is infamous around these parts
Hi Raja,
I went back and forth with the brakes on my car. I wasn't happy with the performance of my stock brakes. Here is what I decided to do, hope it helps
https://www.6speedonline.com/forums/...ht=No+Stopping
Old Nov 11, 2004 | 02:46 PM
hcfly's Avatar
hcfly is infamous around these parts
Grand-Am race cars use the stock brakes with track pads. You can try Hawk pads that are intermediates which are not as loud and sqeaky as track pads but provide a huge improvement over stock pads. In the end, it comes down to how much you want to spend. I put the GT3 brakes on mine and although theyre great, theyre completely unnecessary...even for 465 HP
Old Nov 14, 2004 | 03:14 AM
spr's Avatar
spr
The main problem I experienced was with the ease of wear for stock pads, boiling fluid and the temp range constraints for street purposes. I like the S pagids I run along with motul 5.1. However I am still need gt3 cooling ducts or substitutes however, the wear is reasonble. I am also going to swap that motul for castrol srf as you don't have to change it as much because the wet boiling point is sooo much higher than the motul
Also as I was told the negligible gains from the gt3 brakes- turbo brakes with different carriers, are offset by the great increase in unsprung weight that is why the brembo's are soo much more attractive, I don't remeber which ones they were however when Barry was "schooling me"
Old Nov 14, 2004 | 04:25 AM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
The stock brakes are all you need. The only upgrade I would suggest for heavy track use is Pagid Orange pads and ATE SuperBlue brake fluid. Anything else is pure bling. IMO
One more thing, steel or braided brake lines are not a good idea on the street, in fact they're flat dangerous.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
The Oss
Aug 24, 2015 08:19 PM
PelicanParts.com
996 Vendor Classifieds
Aug 18, 2015 03:45 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 18, 2015 03:43 PM
