Interior LED type numbers
Old Jun 27, 2009 | 09:51 AM
bjarne996's Avatar
bjarne996 is infamous around these parts
I want to replace the interior, trunk and engine compartment bulbs with LEDs. After some investigation I think I have found the correct bulbs at www.superbrightleds.com :
Trunk + engine compartment + interior dome light [6411]:
4410-x9 LED Festoon bulb
Map reading bulbs (either side of dome light) [2825]:
WLED-x6 LED bulb
Step/courtesey lights (door) [2825]:
WLED-x5 LED Wide Angle LED bulb
Has anybody tried these successfully?
Also, is it possible to replace the H7 fog light with a 9-LED H7-WHP9 without triggering the bulb failure warning?
Thanks,
Bjarne
Old Jun 27, 2009 | 01:20 PM
KwlAznKid's Avatar
From: Fremont, CA/ University of California San Diego
KwlAznKid is a glorious beacon of lightKwlAznKid is a glorious beacon of lightKwlAznKid is a glorious beacon of lightKwlAznKid is a glorious beacon of lightKwlAznKid is a glorious beacon of light
all the codes should be here
if you trigger a warning just slap a resistor on and problem solved. good luck
http://www.sylvania.com/ConsumerProd...RG-Results.htm
Old Jul 3, 2009 | 02:31 PM
bjarne996's Avatar
I have now fitted the LEDs. Everything worked fine, except I was unable to fit the 5-LED wide angle bulb inside the door step/courtesey lights . No big problem thought, I used the 6 LED directional bulbs for the doors and the 5 LED wide angle bulbs for the map reading light instead.
Anyway, the correct LEDs should be:
Map reading bulbs (either side of dome light) + Step/courtesey lights (doors) [2825]:
WLED-x6 LED bulb
Old Jul 3, 2009 | 04:38 PM
Wheelman's Avatar
Wheelman is infamous around these parts
Very good information..thanks
Old Jul 4, 2009 | 04:32 PM
bjarne996's Avatar
Thanks!
Old Jul 6, 2009 | 05:03 PM
YellowmanTT's Avatar
YellowmanTT is a glorious beacon of lightYellowmanTT is a glorious beacon of lightYellowmanTT is a glorious beacon of lightYellowmanTT is a glorious beacon of lightYellowmanTT is a glorious beacon of lightYellowmanTT is a glorious beacon of light
I did the leds on the license plate, doors inside overhead, and corner lights. I waiting for the lights inside the headlights and taillight from superbrightleds right now too.
I can try to take some pics if you guys want to see it .
Old Jul 7, 2009 | 01:08 PM
bjarne996's Avatar
It would be great with some pics! Also, if you can post the LED type numbers it would be easier for others to obtain the correct LEDs!
Thanks,
Bjarne
Old Jan 4, 2010 | 11:52 AM
jstrat85's Avatar
jstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to all
would love to see some pics!!
Old Jan 4, 2010 | 10:31 PM
996-Sam's Avatar
996-Sam is infamous around these parts
Does the LED light work correctly with the interior's light dimming feature (i.e. does it dim before turning off)?
COBB Tuning
Jan 1, 2025 09:02 AM
hyboost
Aug 24, 2015 01:45 PM
