Brakes problem please help scary!!!
Old Oct 4, 2009 | 07:55 AM
123packman's Avatar
123packman is infamous around these parts
please help me, when braking hard on a bumpy road, as i put my foot hard on the brakes i seem to get a very good bite, then as my foot is on the pedal braking if i hit a pothole bump etc the pedal goes in a fraction and it feels as if my brakes have slighty let off, this has only happened twice as it has to be a bumpy road or pot hole, my suspension is coilovers and they are very hard as set up for track could this be problem? i own a go karting circuit here in the uk and i have felt simlair on a kart when a axle had moved pushing th piston back in a fraction, the first time u press brake feels like its push it back to normal postion and then if u let off and press again it bites, its almost as if as i hit a hard bump the suspension is so hard it jults the piston back a fraction to create a feeling in the pedal that its now not breaking as well?
this is really hard to exsplain and i really hope somone can help as this happend the other day and i shi* myself scared, as i was braking for a corner i hit a bump it felt like brakes had gone for a 0. second so i released and put my foot back on when they worked pefect????
please some one can help me ????????????????????
Old Oct 4, 2009 | 08:05 AM
Lerxst's Avatar
Lerxst is infamous around these parts
If it's only for a fraction of a second, that sounds like your ABS kicking in, which is perfectly normal.
- You're on the brakes
- Your wheel hits a pothole or bump, losing traction
- With no resistance to keep the wheel turning, the braking force will lock-up the wheel.
- The ABS senses the lockup and will immediately let off the brakes for a moment then reapply them.
Next time this happens, try keeping your foot down (that's the best technique for ABS). If the brakes come back right away, it's fine.
Old Oct 4, 2009 | 10:42 AM
ske's Avatar
ske
ske is infamous around these parts
sounds like normal ABS behavior. avoid the potholes though
Old Oct 4, 2009 | 01:30 PM
BDPorsche's Avatar
BDPorsche is infamous around these parts
Definitely sounds like your ABS... unless you like me where you get a warning engine ABS light... crap!
Old Oct 5, 2009 | 08:59 AM
92tsiawd's Avatar
92tsiawd is infamous around these parts
Could be air in the lines...try bleeding your brakes
Old Oct 5, 2009 | 04:09 PM
c2mojo's Avatar
c2mojo is infamous around these parts
ABS working to help you like everyone has stated
Old Oct 8, 2009 | 10:05 AM
Dervish's Avatar
Dervish is infamous around these parts
Yup, ABS kicking, get it all the time since I fitted KW-V3s. The harder suspension means the wheels lock quicker when hitting bumps hence you feeling the ABS more...
Old Oct 9, 2009 | 12:40 AM
dnitake's Avatar
dnitake is infamous around these parts
Know what you mean. Was happening a lot. Had 2 offs at the track because of it. Pulled the ABS fuse and life was a bit better, but only a bit. Don't do that of course, but had to see if it was the ABS. Heavy braking and either bumps or a slick surface cause the ABS to partially release the brakes. They don't come back. Have to release the pedal and re-apply quickly. Don't know of a reasonable fix other than don't do that. Pinged quite a few folks w/ no real good answer or solution other than racing ABS. GL.
Old Oct 9, 2009 | 06:00 AM
123packman's Avatar
brakes
thanks to all your answers thats why i love this forum so much, now i know exactly why it happened and the reason when doing it again, i didnt have any problems on track it was a very good track no bumps, just need to go carful on the road, lol thanks again guys
alevine
Nov 4, 2015 10:05 AM
LiquidElephant
Aug 27, 2015 06:17 PM
rnl
Aug 26, 2015 02:36 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
