Exhaust removal help
Old May 2, 2010 | 07:29 PM
jax996's Avatar
jax996 is infamous around these parts
Hello all. I am trying to remove my exhaust and it seems very straight forward. I am having a hell of a time getting the clamp that connects to the catalytic off since the two carriage bolts are rusted and won't budge. I have used PB blaster and no go.... Suggestions?
Old May 2, 2010 | 07:35 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
lots and lots of PB blaster overnight....warm up the car and get the bolts heated up a little......get a breaker bar that's as long as you can....and tug as hard as you can
Old May 3, 2010 | 12:37 AM
MkC2S's Avatar
I just spray alot of WD-40 on mine..& let it soak for awhile...an extension bar & alot of elbow grease will do the trick..It also help if you jack the car up to have extra clearance.
Old May 3, 2010 | 06:16 AM
Brando's Avatar
Brando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud of
Cool
You need a compressor and an air gun.
Run it by a muffler shop and have them hit it.
Old May 3, 2010 | 08:03 AM
Omarcoolguy's Avatar
Omarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant future
take it to a shop...there prob goonne need to use a torch to looses the bolts
Old May 3, 2010 | 04:17 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Kind of hard to drive it to a shop with the broken motor mount. Get a big breaker bar and torque that thing off. You may break the bolts, I know I did on one of mine a couple of years back. Replaced both clamps on mine, but you may be able to replace just the bolts. Chicago winters and exhaust systems don't like each other.
Old May 3, 2010 | 08:07 PM
Codyk's Avatar
Codyk is infamous around these parts
I've always found that drinking alot of beer while swearing and screaming at the bolt helps.... Or when in doubt use and air gun
Old May 4, 2010 | 03:19 PM
bjarne996's Avatar
bjarne996 is infamous around these parts
Remember that you will only need to loosen one of the two bolts on each of the clamps to separate the exhausts from the cats.
That saved me when one of the bolts was stuck even after 24h soaking in WD40.
Good luck!
Old May 4, 2010 | 04:13 PM
HxCforlife's Avatar
Awaiting Email Confirmation
HxCforlife has a spectacular aura aboutHxCforlife has a spectacular aura about
I cut mine out and just replaced them with the fabspeed ones. They are amazing.
Jul 29, 2019 11:13 AM
drinaldis
Sep 28, 2015 01:37 PM
I'mAllIn
Sep 11, 2015 06:38 AM
bmwtmx
Aug 26, 2015 07:26 AM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
