Battery maintainer question
Old Jun 2, 2010 | 10:22 AM
delirium's Avatar
delirium is infamous around these parts
I just bought a black and decker battery maintainer to keep my battery from dying. This charger/maintainer has an option to use 1 amp or 2 amps setting, and I'm guessing that I should use the 1 amp setting for battery maintenance, but can anyone confirm that is correct?
Thanks!
Product:
http://blackanddecker.com/ProductGui...roductID=15572
Product manual:
http://www.dewaltservicenet.com/docu...56303,BM2B.pdf
Old Oct 24, 2010 | 09:03 AM
carsareart's Avatar
carsareart is infamous around these parts
I have been looking at maintainers too. I looked at one at Autozone and the Battery Tender online. Where are you going to put your leads to connect to the battery/maintainer?
I would set it at the lowest possible setting and monitor and adjust as needed. Is this a charger or maintainer? How does it seem to be doing? These are the two I have been looking at. Schumacher/1.5 Amps at Autozone, about 27.00
Battery Tender Plus from Amazon about 46.00
Old Oct 24, 2010 | 12:41 PM
Slider's Avatar
I'm using a Deltran battery tender junior. Plug it in and walk away. They are bout $40.
http://batterytender.com/battery-ten...-at-0-75a.html
Old Oct 24, 2010 | 08:50 PM
djantlive's Avatar
your black and decker link doesn't work. i am guessing that's a trickle charger instead of a maintainer.
i would get a battery tender instead.
Old Oct 26, 2010 | 03:10 PM
Wicked 996's Avatar
Wicked 996 is infamous around these partsWicked 996 is infamous around these parts
http://batterytender.com/battery-ten...-at-1-25a.html
get this and be done with it. Mine stays on this all the time.
Old Oct 26, 2010 | 08:54 PM
alpine003's Avatar
I've had the Battery Tender Junior and it was more than sufficient for my last 3 cars.
http://www.amazon.com/Battery-Tender...8148016&sr=8-1
Back to the OP, yes 1 amp is sufficient.
Old Oct 27, 2010 | 06:21 PM
carsareart's Avatar
Where do you have your leads for the battery maintainer? Did you have the wires exit just in front of the windshield? I am thinking this is what I will do. Do you keep a cover on your car when stored?
Old Oct 28, 2010 | 10:21 AM
Millenium_009's Avatar
Millenium_009 is infamous around these parts
Thumbs up OEM Battery Maintainer
I use the OEM from Porsche.
It cost a little more but hooks up via the cigarette lighter socket.
It also has a feedback loop monitor to monitor charging and full charge.
I plug my car up anytime I don't anticipate to drive it for more than a week.
I would recommend it.
I think part number is 95504490054
see attached photo
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
DetomasoGTS74
Nov 11, 2015 09:01 AM
DSCOFF
Aug 23, 2015 01:22 PM
