Clunking noise front suspension
Been having this problem with a clunking or something loose in the front suspension for a while now, when the car goes on rough roads or uneven surface, there is a noise..... but i've changed just about the entire front suspension and I'm still getting that noise, anyone can help?
things that are new and changed to - Pss9 coil overs, oem strut mounts, H&R sway bar, AP sway bar links, oem side and lower control arms, toe arms.
I had clunking noises at slow speed over bumps, and some creaking when turning at slow speed. This was on 2 year PSS10s. We do have rotten roads here in MN. All the noise went away with a single replacement part:
This link came with the PSS10s. If you grab it, it should be very firm. On one side it was slightly moveable (the technician showed me on the lift). This translated into noise over bumps at slow speed and general creaking noises while turning. All at low speed only. Replacing one of them (about a $50 dollar part) fixed things for me.
Of course there are a ton of other things that can clunk, rattle, creak, on these things . . .
I had a similar perplexing issue and was embarressed to drive people in my car...turned out it was the upper strut mounts - there was no more rubber left and I was just clunking around. It was hard to see without getting in there, but a relatively inexpensive fix. I also fitted the Bilstein washer retrofit for PSS9 again, minimal cost and now it feels and sounds like a Porsche again.
yes, the drop links for the swaybar.. very easy to replace.. im doing mine in a weekend or 2... supposed to be about 20 min per side... :-)
here is a link http://cgi.ebay.com/ebaymotors/ws/eB...d=140318011449
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
