LED Interior Lights
Old Dec 31, 2010 | 03:12 PM
DeAd-EyE's Avatar
DeAd-EyE is infamous around these parts
LED Interior Lights
Has anyone changed their interior lighting to LED lights? If so, do you have the cross-over numbers for an equivalent LED?
Old Jan 1, 2011 | 11:33 AM
gu9cci's Avatar
gu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond repute
i subscribed
Old Jan 1, 2011 | 12:47 PM
bjarne996's Avatar
bjarne996 is infamous around these parts
I have done this, see post #3 in this thread:
https://www.6speedonline.com/forums/...e-numbers.html
Old Jan 1, 2011 | 02:35 PM
gu9cci's Avatar
what about dome light?...
Old Jan 1, 2011 | 02:55 PM
bjarne996's Avatar
OK, I'll repost the www.superbrightleds.com type numbers for simplicity:
Trunk light (1pc),
Engine compartment light (1pc) and
Interior dome light (1pc) [6411]:
  • 4410-x9 LED Festoon bulb
Map reading bulbs (either side of dome light) (2pc) and
Step/courtesey lights (in door) (2pc) [2825]:
  • WLED-x6 LED bulb
Old Jan 1, 2011 | 03:22 PM
gu9cci's Avatar
im sorry but i dont understand how manny to buy and which ones....
Can you post better explanation?
for example....for dome light,courtessy light you need 23xx bulbs -4pc.
and on on
Old Jan 1, 2011 | 04:21 PM
bjarne996's Avatar
and on on
OK, I've updated the post with the number of bulbs you need of each type. In total you'll need 3 of the first type (or only 1 if you do not want the trunk and engine compartment lights) and 4 of the second type.
Old Jan 1, 2011 | 07:09 PM
DeAd-EyE's Avatar
Thank you very much good sir! For the WLED's, wouldn't the WLED-xHP6_DAC or WLED-xHP6 be better choices because they emit at 120 and 360 degrees respectivly?
Also, were these just plug n' play replacements or was sodering of special sockets required?
Edit: Just noticed they also have UV lights...isn't UV supposed to be bad for you? Or is it the same stuff as blacklights from the 80's?
Old Jan 2, 2011 | 04:55 AM
bjarne996's Avatar
Due to the reclined sockets, I do not think these will work.
Just as the: WLED-x5 LED Wide Angle LED I first planned to use in the door lights does NOT work.
I would use the ones listed in post #5 above, they work very well.
Nope, the sockets are the same. Just plug and play.
Old Jan 2, 2011 | 05:36 AM
100plus's Avatar
100plus is infamous around these parts
Good Mod!
Old Jan 6, 2011 | 09:06 AM
Astacun's Avatar
Astacun is infamous around these parts
Great mod. One more question. What "color" are you guys using? Cool white, natural white or warm white?
Old Jan 6, 2011 | 10:51 AM
bjarne996's Avatar
I chose cool white, which gives a bluish light that is easily distinguishable from the standard light. I guess natural light would give a more "high tech" OEM look, while warm white will be close to the "yellow" OEM look.
Old Aug 13, 2013 | 07:28 AM
antagron's Avatar
antagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant futureantagron has a brilliant future
Hey guys - I bought the LEDs as specified. Is there one for the glove compartment box? It seems to be 1/3 smaller than the trunk lights. Also, any tips for taking off the map light cover? I couldn't quite figure it out in my 2 minutes of poking around (didn't want to break anything). thanks!
Old Aug 13, 2013 | 08:29 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Map light cover pulls right out. You pull from the from if I remember correctly.
No idea on the glove box...I don't have one.
Old Aug 14, 2013 | 04:19 AM
Wausau 911's Avatar
Wausau 911 is infamous around these parts
Go to the superbright website and put in your car info, it will bring up the appropriate bulbs replacement for different areas of your car.
