Popping out of second gear
Old Mar 4, 2012 | 06:11 AM
skota's Avatar
skota is infamous around these parts
I have this strange issue where the gear lever pops out of gear when I release the clutch. It only happens a few times when the car is cold but goes away after a few minutes.
I'm suspecting the transmission fluid needs changing, any thoughts?
What fluid would you recommend?
Thank you
Old Mar 4, 2012 | 08:28 AM
inclined's Avatar
inclined is infamous around these parts
I would check out gbox (gboxweb.com) and their upgraded 2nd gear detent. It's only around $150, easy to install and fixes a good deal of people's issues with second gear grind and pop-out. The swap took me about 15 minutes to do and I haven't had any issues since.
Good luck
Old Mar 4, 2012 | 08:57 AM
logray's Avatar
logray is infamous around these partslogray is infamous around these parts
Here's a direct link to the 2nd gear detent website:
http://www.gboxweb.com/detent.html
Old Mar 4, 2012 | 04:52 PM
thankswww's Avatar
thankswww is infamous around these parts
Mine does it when it's freezing outside too. I don't think the car is actually popping OUT of gear, I think it's more of an "It wasn't all the way into gear in the first place" issue. I've had other vehicles that didn't want to smoothly change gears when it was freezing outside too. Not unique to the 996.
The real problem arises when you are already in second gear with your foot off the clutch driving, and the car pops out of gear randomly. Then you have big problems.
Old Mar 4, 2012 | 05:42 PM
skota's Avatar
Bravo guys, great information. Thanks so much
Old Mar 4, 2012 | 08:36 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
The Gbox detent is supposed to be great, but wow, $149! When if was first introduced it was $69. I guess everyone is entitled to make a profit but that is over double the old price.
Old Mar 5, 2012 | 02:14 PM
scantu's Avatar
scantu is infamous around these parts
mine popped out about 50% of the time..... gbox detent worked 100% I have never had the gear pop out since.
Old Mar 6, 2012 | 03:58 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
Here is a DIY for a turbo. I don't know if the turbo is the same as the NA but thought it might help if it is similar.
http://www.renntrack.com/forums/show...278-Detent-DIY
Old Mar 8, 2012 | 03:55 AM
mikegr's Avatar
mikegr is infamous around these parts
Installing a 997 short shift, would this solve the problem?
Old Mar 8, 2012 | 09:21 AM
scantu's Avatar
Sorry Mike, but installing a shirt shift kit WILL NOT fix this problem. The case of the popping out symptom is internal gearbox. the tolerences for second gear are super tight and G-box has created a detent to replace the factory piece to increase this. A shifter only changes the "feel" of your movement from one gear to the next. its all about leverage and linkage.
Old Apr 11, 2020 | 10:54 AM
wkf94025's Avatar
wkf94025 is infamous around these parts
Despite my specific attempt to trigger 2nd gear pop out during test drive in February before purchasing my 2001 996TT, I experienced it for the first time last night decelerating during a boost test run. Bummed. It's been a few years since anyone posted on this thread. I am curious if the GBox detent is still the recommended inexpensive fix.
Old Apr 11, 2020 | 09:52 PM
nevek89's Avatar
nevek89 is infamous around these parts
Run, don't walk, to get the Gbox Kit.
I had a shop try to tell me I needed a new transmission, and that they had 20+ years experience working on Porsches blah blah blah. Turned out all I needed was the Gbox Kit, 150$ and good to go. I know he raised the price from 69$-150$ but they saved so much money in maintenance and headaches its well worth it.
I've put 10,000 Miles on my gbox kit and have not popped out of gear even once.
You can read more about this issue "2nd gear detent" is what to Google.
Old May 6, 2020 | 01:46 PM
riceball's Avatar
riceball is infamous around these parts
New to forum
Hi, I'm new to the site. Is gboxweb.com the only company that makes the part?
Old May 16, 2020 | 11:38 PM
Rbogh911's Avatar
Rbogh911 is infamous around these parts
think so but i may be wrong. the alternative is to reshim the gear stack i understand.
007 Vantage
Oct 8, 2015 08:35 PM
Oct 6, 2015 06:13 PM
km90265
Sep 27, 2015 10:57 PM
panas001
Sep 27, 2015 02:51 PM
