Clutch might be going.
Old May 5, 2012 | 09:58 AM
danrx3's Avatar
danrx3 is infamous around these parts
My car is making a strange noise when I step on the clutch. I think I might need to have clutch replaced. Car is going to shop on Monday. Let me know what to expect from a cost perspective so I don't get taken for a ride. It has about 50,000 highway miles on it.
Thanks,
Dan
2003 996 C4S
Old May 5, 2012 | 11:41 AM
theoilman's Avatar
theoilman is infamous around these parts
If getting it replaced, do the IMS bearing, rear main seal and air oil separator while you're in there!
Old May 5, 2012 | 11:52 AM
danrx3's Avatar
already replaced ims bearing and rms at 35,000
dan
Old May 5, 2012 | 11:53 AM
theoilman's Avatar
Consider doing the AOS then... Much easier when the tranny is dropped. It's only like a $50 part but could cost you big $$$ in labor WHEN it fails at a later time.
Old May 5, 2012 | 03:10 PM
WDC 911's Avatar
WDC 911 is infamous around these parts
$1500
Originally Posted by danrx3
my car is making a strange noise when i step on the clutch. I think i might need to have clutch replaced. Car is going to shop on monday. Let me know what to expect from a cost perspective so i don't get taken for a ride. It has about 50,000 highway miles on it.
Thanks,
dan
2003 996 c4s
Old May 9, 2012 | 12:35 PM
danrx3's Avatar
thanks
thanks,
just had clutch replaced. cost 1600 (800 for parts and 800 for labor).
clutch and flywheel were fine. a plastic piece on the clutch pressure plate throwout bearing broke.
dan
Old May 9, 2012 | 12:38 PM
danrx3's Avatar
aos
fyi - i asked about replacing the aos as part of the clutch job. the shop tested the vacuum and did not recommend replacing the aos since the pressure was fine.
dan
Old May 9, 2012 | 12:43 PM
Byprodriver's Avatar
Byprodriver is infamous around these parts
dan
Sounds like you have a good shop! FYI AOS is $100+ for the part.
Old May 9, 2012 | 12:54 PM
stevet's Avatar
stevet is infamous around these parts
Danrx,
Who is the shop your using? Im also in Jersey.
Thx.
Old May 9, 2012 | 05:39 PM
Gonzo911's Avatar
Gonzo911 is infamous around these parts
dan
I had a small oil leak in the AOS breather hose about 6 months ago. I also asked about replacing the AOS but they did the same test and it was fine. Last weekend the AOS crapped out. $1150 to replace (54k miles). You may want to go ahead and have it done since the AOS is one of those repairs you will have to deal with sooner or later. IMHO.
Bmw M3 Guy
Feb 21, 2018 09:29 AM
ECS Tuning - BMW
Sep 16, 2015 07:20 AM
ECS Tuning - VW
Sep 9, 2015 03:11 PM
ECS Tuning - VW
Sep 9, 2015 12:01 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
