Need Help with "Gundo Hack" Bypass
Old Jun 11, 2012 | 04:18 PM
Hind's Avatar
Hind is infamous around these parts
Took off one of my mufflers and took it to a muffler shop to have the gundo hack welded between the in/out pipes. But after inspecting my muffler, its not the same as the pictures I've seen online. It seems almost impossible to perform this modification. The Muffler mechanic couldnt find a good spot to make the connection.
I have a flex section and on the out pipe I have a bracket. no room for a 2'' pipe. For reference the current piping on the muffler is 2" for scale. Thoughts, help?
Old Jun 11, 2012 | 05:44 PM
Dennis C's Avatar
It looks like a standard 996 muffler. The two options I've seen are one that connects the inlet and outlet plumbing, like the Fister mufflers. This approach partially bypasses the entire muffler. I've also seen a pipe welded between the "cap" in the muffler case and the outlet plumbing, effectively bypassing one chamber of the muffler. Here's how it looks on my Fisters:
Old Jun 11, 2012 | 10:14 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
When I had mine done, I only looked for someone with experience doing this. Ask around for someone in your area who has done these. My guy did all the work why are you taking things apart?
Old Jun 11, 2012 | 10:57 PM
996_911C2_Dhru's Avatar
996_911C2_Dhru is infamous around these parts
Here is mine. Mine are MKII mufflers with the Sport Knockout connected to the outlet and
the inlet/outlet connected with a straight pipe. Sounds amazing All work done with 304 Stainless.
Old Jun 12, 2012 | 06:11 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Take them to Vortex Motorsporst on Hillsborough ave. out by the airport. They can do it, ask for Sara and she can help you.
I'm taking mine there today
Old Jun 12, 2012 | 06:34 AM
wyovino's Avatar
wyovino is a jewel in the roughwyovino is a jewel in the roughwyovino is a jewel in the rough
Send them to Fister. It will be done right and the welds will be perfect.
Old Jun 12, 2012 | 03:43 PM
Hind's Avatar
Ok, thanks for all the advice. I'll see about finding someone who has done this.
Old Jun 12, 2012 | 08:08 PM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
Question
do you have a sound clip?
Old Jun 13, 2012 | 06:41 PM
Not the best sound quality..but here you go
pwdrhound
Sep 13, 2016 10:44 AM
nharley
Oct 6, 2015 06:14 PM
