water pumps a common problem?
Old Nov 1, 2012 | 10:01 AM
soreshoulder's Avatar
soreshoulder is infamous around these parts
I just replaced the pump on my 88k mile '99 in August and its already leaking. Its under warranty, obviously, but I'm wondering if OEM is the only way to go??
Old Nov 1, 2012 | 11:33 AM
Byprodriver's Avatar
Byprodriver is infamous around these parts
Thumbs down
Yes, there are alot of cheap China made copies out there. Be sure the replacement has a plastic impeller so if it fails it won't chew up the case & potentially ruin the case. Perhaps you should upgrade your mechanic shop to one with more 996 experience too.
Old Nov 1, 2012 | 11:37 AM
I did that one on my own, lol.
Old Nov 1, 2012 | 11:50 AM
I think Laslo is the company that makes the oem pump. So you don't need to buy the WP from a dealer, just get the oem pump somewhere else.
Old Nov 1, 2012 | 11:53 AM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
Mine failed on my 1999 C2 at 40K miles.
Old Nov 1, 2012 | 01:36 PM
Dennis C's Avatar
They are considered a "disposable" item by many people. They should be changed periodically even if they haven't failed.
Old Nov 1, 2012 | 02:06 PM
dennish's Avatar
dennish is infamous around these parts
OEM- got mine at Sunset Porsche. Good price
Old Nov 1, 2012 | 04:15 PM
invius's Avatar
invius is infamous around these parts
Mine just failed at 83k on my '99 C2, and it looked VERY original when I took it out.. I have read numerous people that have had problems with non OEM pumps, so I bought mine from Sunset as they were cheaper than anyone else, had the latest iteration of it, and shipped it quickly and cheaply. Was a bit of a PITA to put in, but it's in, and working just fine. I've seen replacement figures for them at 4 years 50k miles, so you don't run into any issues with it going out on its own.
Old Nov 1, 2012 | 06:43 PM
its a very slow leak at the moment. I'll see if I can get my money back in lieu of another knock off...grr
Old Nov 1, 2012 | 08:07 PM
invius's Avatar
That's what I would do, but not sure they will be willing to refund, but would definitely put an OEM one in...if you did yours, you know the pain in the *** that the job is...I got a lot of satisfaction knowing that I wasn't going to need to do that for another 4+ years once I got mine in and completed.
Old Nov 1, 2012 | 10:26 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Your leaky replacement pump is obviously defective and needs to be replaced under warranty. It's not an indictment of the quality of OEM pumps. Did you purchase, and install, a Porsche approved OEM pump or an aftermarket pump?
Old Nov 3, 2012 | 11:58 AM
kromdom's Avatar
kromdom is infamous around these parts
I am guessing from his post that IN HINDSIGHT, he wished he went OEM.
Old Nov 3, 2012 | 12:12 PM
hroussard's Avatar
If you have a water leak - of ANY kind - it's time for repair. You do not want your pump to fail , overheat your engine and end up with a pile of parts in the corner of your garage.
Old Nov 5, 2012 | 07:56 AM
the original pump gave plenty of warning before it went, this one is just starting to drip. I'm fairly mechanical and didn't find the job overly difficult. I'll definitely go with OEM the next time, though. Thanks for the help.
Old Nov 5, 2012 | 02:00 PM
Reborn996's Avatar
Reborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to behold
Byprodriver, I noticed you said get a plastic impeller version... but I ordered from Suncoast earlier this year and it was still metal for the latest version from Porsche. Is there a part number for the Porsche version with plastic impeller you can reference?
David
