Weight of 3.6 liter engine
Old Oct 19, 2014 | 08:21 PM
JoJoRizing's Avatar
JoJoRizing is infamous around these parts
Does anyone know the weight of a 2002 porsche 911 996 3.6 liter engine. I want to know how heavy my motor will be when I remove the two rear bolts to lower the motor 3 inches to get my coolant expansion tank out. I intend to use a jack that is made to lift motorcycles. It is rated to support 1500 pounds. I like the jack that I intend to use because it has a wide wheel base, will not tent to turn over, and has a lot of surface area that can be spread out to support the entire width and depth of the oil pan. Hopefully reducing the possibility of damaging the oil pan. Just want to make sure that the engine will not exceed the 1500 pound rating of the lift.
Thanks for the help.
Old Oct 20, 2014 | 08:01 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
If I recall 512lbs give or take.
Old Oct 24, 2014 | 11:59 AM
Byprodriver's Avatar
Byprodriver is infamous around these parts
Fully dressed it's in the 450 lbs. range Manual trans added about 130.
Here is a 3.6 on a table jack with max capacity 500 lbs.
Old Oct 26, 2014 | 08:02 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
I have used my motorcycle jack several times to lower my engine. My Harley weighs much more than the engine.
Old Oct 26, 2014 | 08:31 PM
JoJoRizing's Avatar
Thanks to all for your responses. I did manage to use the motorcycle jack that I got at sears. It was rated up to 1500 pounds and it worked nicely. I did manage to get that !;(*#?ing! expansion tank in today. I will go into detail about that odisy in my thread titled "coolant leak".
Old Oct 26, 2014 | 08:33 PM
JoJoRizing's Avatar
Motorcycle jack from Sears 1500# capacity only $175
Old Oct 26, 2014 | 08:35 PM
JoJoRizing's Avatar
Old Oct 27, 2014 | 05:08 PM
Dharn55's Avatar
I always use a piece of 2x12 on top of my jack to spread the load. Just an idea.
Old Oct 31, 2014 | 03:42 PM
Fierofly's Avatar
Fierofly is infamous around these parts
Engine Removal
LS3 Install
Old Oct 31, 2014 | 04:02 PM
JoJoRizing's Avatar
wow... keep me up to date with your progress
Jul 29, 2019 11:13 AM
COBB Tuning
Mar 29, 2016 09:26 PM
stevenrmusic
Bentley
17
Nov 12, 2015 05:53 PM
Sales@RSW
Sep 3, 2015 09:34 AM
