Please Help...? regarding H&R coilover
Old Nov 18, 2003 | 04:13 PM
Curves4S's Avatar
Curves4S is infamous around these parts
I have an 03' manual C4S and am about to purchase the revised H&R coilover setup. The problem is that there is no listing for a C4S coilover---it is only offered for a C4 or a Turbo.
I originally purchased the H&R coilover set up for a Turbo since the C4S has the same suspension (correct??) but when i double checked with H&R, they told me to purchase the coilover for the C4. This didn't make sense to me and got me worried so i returned the damn thing.
Can anyone tell me which one i'm supposed to purchase?? I original thought the Turbo setup would work but the H&R tech told me differently...Can anyone clear this up?
I also purchased the H&R sway bars for the Turbo with the intention of putting it on my C4S, since they don't make one specific for a C4S. Will this work or should i just return these also?
I have 24hrs before the 20% coupon for Performance products expires so i need help ASAP! thanks
Old Nov 18, 2003 | 11:01 PM
miki4s's Avatar
miki4s is infamous around these parts
hey whats up man. I'd like to know the answers to your questions too. you gotta cruise down to OC again and hit up the newport show. Check out the spugen site we are having a BBQ on the 23rd. This is Miki with the silver c4s by the way
Old Nov 19, 2003 | 02:42 AM
Curves4S's Avatar
found the answer...we need the c4 setup on our cars...
not sure if the H&R turbo sway bars work for our vehicles but i believe the GT3 do.
Old Nov 19, 2003 | 03:03 AM
20C4S's Avatar
for what i know u should be using the Turbo set up (at least for RUF & Bilstein set up). if u decide to go with H&R, good luck! i had horrible experience with them.
Old Nov 19, 2003 | 09:05 PM
Curves4S's Avatar
I ended up getting the Bilstein Pss-9 setup for a C4 (to use on my C4S) I was told H&R developed the spring for this system, so i figure the spring rate would be the same. A Turbo is supposedly 300lbs heavier than a C4S so the spring rate is stiffer, the springs used in the coilover for a C4 is not as stiff so the difference in weight b/w C4 & C4S is less as opposed to the weight difference b/w C4S & a Turbo.
I paid just over $2500 for the Pss-9 setup. Is this a good price or did i pay too much?
I think i have the Euro version because the box is in German. Whats the difference between US and Euro version?
Old Nov 19, 2003 | 11:53 PM
20C4S's Avatar
03,
can u tell just by looking at it the US version is different?
Old Nov 20, 2003 | 12:40 AM
Curves4S's Avatar
O3 C4S,
the performance products catalog didn't offer a Turbo setup for the pss-9's. Why wouldn't the C4 setup work? wouldn't the spring rate be the same as the H&R setup for a C4 since H&R makes the springs for the Pss-9's? (at least thats what i heard)
looking at the box right now its in both English and German, How do i tell what version it is by looking at the coilover?
Old Nov 20, 2003 | 10:42 AM
Curves4S's Avatar
that's what i had originally thought but...I was told by some people from PCA that it isn't exactly the same...the turbo springs have a higher spring rate because the engine is approx 300lbs heavier, I got the same story when i talked to the H&R techs.
People have been telling me the C4 setup is a better match than the turbo.
Old Nov 20, 2003 | 06:23 PM
Curves4S's Avatar
I checked with Gert (carnewal) and he confirmed that the pss-9 setup for a C4 is the correct one to use for my C4S.
thanks
Old Nov 21, 2003 | 12:06 AM
20C4S's Avatar
Gert sold me the Turbo one for C4S earlier.
Old Nov 21, 2003 | 01:54 AM
Curves4S's Avatar
Technically you could fit either.
The Turbo's spring rate is stiffer to support the extra 300lbs from the turbo engine.
The C4S is just slightly heavier than a C4 due to the widebody but a lot lighter than the turbo. the spring rate on the C4 setup works better because the difference in spring stiffness & car weight is less. This is what i was told by both and H&R tech and Gert from carnewal.
Old Nov 21, 2003 | 06:57 PM
msindi's Avatar
I am selling my Euro PSS-9 (for 996TT) if ur interested...
Feb 24, 2016 01:10 PM
mrmaass
Oct 9, 2015 01:32 PM
Sep 28, 2015 02:19 PM
MONKY LONDON
Sep 28, 2015 07:16 AM
Zero911
Sep 24, 2015 06:33 PM
