Bad load switch. >.03 amp battery drain
Old Aug 21, 2018 | 11:18 AM
swampyankee's Avatar
swampyankee is infamous around these parts
Took out radio fuse 7.5 amp and battery drain stopped. Suspect bad load switch need to locate where it is and replace the component. Need help-Swampyankee.( expirienced technician)
Old Aug 23, 2018 | 05:50 AM
ZuffenZeus's Avatar
ZuffenZeus is infamous around these parts
What radio setup do you have? That's definitely a lot of parasitic loss there. How long did it take to drain a full battery?
Old Aug 23, 2018 | 01:36 PM
battery drain problem
It has the stock porshe radio and the new porshe battery will drain out within 1.5 to 2 weeks sitting. going to continue investigating.
I bought the car at a Barret Jackson auction not knowing it had an electrical problem. Nice car tho.
thanks b3freak.
1999 Porshe Carrera 996 cabriolet want to fix and sell and pay off loan ASAP
Old Aug 23, 2018 | 01:40 PM
ZuffenZeus's Avatar
thanks b3
If the radio is turned off, it should drain the battery in that length of time. Most of the stock radios use very little battery to keep memory active. I would imagine either you have a faulty radio or something not turning off with the radio like a frunk amp.. which is controlled by the head unit. What model of car? Radio model?
Old Aug 23, 2018 | 01:42 PM
thanks b3freak.
Old Aug 23, 2018 | 01:46 PM
ZuffenZeus's Avatar
thanks b3freak.
Well, I would encourage you to investigate the situation using a multimeter. That will give you an idea of what is drawing current when the car is turned off. By process of elimination, test each unit on the stereo starting with the frunk amp, CD changer (if you have one), and then lastly, the head unit.
All the best! Hope you find the culprit.
Old Aug 23, 2018 | 01:53 PM
Right. Going to do that and unplug components and switches till I find it. Thanks a lot b3Freak
Old Aug 25, 2018 | 10:46 AM
ZuffenZeus's Avatar
Let us know how it works out!
03EvoIII
Mar 17, 2015 10:41 PM
CorruptedSanity
Jun 2, 2010 07:00 AM
Cayenne 955/957
Feb 16, 2009 09:00 AM
