Rear main seal oil leak.
Old Dec 18, 2003 | 01:55 PM
Greyghost's Avatar
Greyghost is infamous around these parts
I just found out I have an oil leak in my rear main seal on my 2004 996 with only 3000 miles. I've heard this was a problem on earlier 996 models but has any one else had this issue?
Thankfully there's a warranty but what a freakin *****!
Old Dec 18, 2003 | 02:11 PM
WARDHOG's Avatar
WARDHOG is infamous around these parts
So fricking early?! That really sucks.
Old Dec 18, 2003 | 02:14 PM
Gary (Fl)'s Avatar
The Newest "Bling King"
Gary (Fl) is infamous around these parts
I cannot believe they have had the same problem since 1999.....
So much for quality control....
Old Dec 18, 2003 | 02:15 PM
Greyghost's Avatar
Do you think it matters that I readline it in every gear up to 4th?
Old Dec 18, 2003 | 02:24 PM
msindi's Avatar
LOL - redlining it does nothelp...
I had the same problem on my 99 C4..they replaced the RMS and gave me a new clutch under warranty
Old Dec 18, 2003 | 02:26 PM
Greyghost's Avatar
Wow... maybe I should complain about slipping or something in order to get me a new clutch too!
Old Dec 18, 2003 | 02:40 PM
Sloth's Avatar
Sloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud of
Thats a ***** Britt, sorry to hear that. Some cars get them, others do not (like my 2/98 build 996). If the clutch is worn or you were thinking of upgrading the clutch and flywheel, now is the time to do it while they have her all apart.
Have they told you if they can repair it or are you getting a new engine?
Old Dec 18, 2003 | 03:14 PM
RobynC's Avatar
Porsche Chick
RobynC is infamous around these partsRobynC is infamous around these parts
You only redline it up to fourth?!? No guts no glory! Come on, live a little!
Oh, I've had a few RMS leaks (FIVE). It's as common as Arctic Silver on a Porsche.
My advice to you:
1. Have them measure the concentricity of the crank. If it is out of tolerance, it could possibly warrant an engine replacement.
2. If you desire, have them replace your oil with fresh oil. If they change ONLY the RMS and not the Interemediate Shaft Seal, they do not drain the oil. Thus the old oil is left in the car. If they replace both the RSM and the ISS, they do drain the oil. If you do not ask, and offer to pay for fresh oil, they simply put your old oil back in the car.
3. If you had more miles, I would have them take a look at your clutch, but that is a non-issue for you with only 3000 miles.
Side note: Depending on how bad the leak is/was, at times, oil can drip down upon the flywheel, causing a slight vibration when taking off. If this is the case, the dealers are allowed to replace the flywheel as part of this warranty repair.
Good luck! To me, it's become quite comical. It's more of an inconvenience then anything. But, everyone opinion varies on that subject.
RobynC
Old Dec 18, 2003 | 03:30 PM
SANDOVAL's Avatar
Banned by Moderators
SANDOVAL has a spectacular aura aboutSANDOVAL has a spectacular aura aboutSANDOVAL has a spectacular aura about
Are clutches covered under Warranty?
Old Dec 18, 2003 | 03:41 PM
RobynC's Avatar
Porsche Chick
No, not covered. However some have given concessions for this repair at cost (some even gratis) when your car is in for an RMS repair. Labor is already taken care of due to the repair. The transmission is dropped during an RMS/ISS replaecment.
I've had it done twice. One I paid for, the other I didn't. Long story on why it's twice. Suffice it to say, I had 80% left on my clutch, as I was getting a new engine, I opted to just start fresh (Porsche took care of this one for me, thank you Porsche!).
Second one happened when a valet fried my clutch and toasted my flywheel. I paid for that one, but it came at a time when I had an oil leak, so I paid parts only. (I would rather take the bus, then ever, ever leave my car with a valet again.)
Old Dec 18, 2003 | 03:45 PM
Greyghost's Avatar
Thanks for the input RobynC. I will see what I can get the dealer to do.
Old Dec 18, 2003 | 04:22 PM
RDH's Avatar
RDH
RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !
Sorry about your car Britt. Buy alot of cat litter
Old Dec 18, 2003 | 10:31 PM
doncapecod's Avatar
doncapecod is infamous around these parts
I wonder if this is Porsches biggest engineering or quality control screw-up! I just turned paranoid waiting for something to happen to mine
Old Dec 19, 2003 | 12:26 AM
Itzkirb's Avatar
Robyn is the queen on the RMS!
Hey Don, I like your member title...HAHAHAAH
Old Dec 19, 2003 | 12:42 AM
msindi's Avatar
FYI - my clutch was replaced with RMS cause oil leaked onto my clutch
