premature engine failure?
Old Sep 20, 2006 | 10:40 PM
chrisanderson's Avatar
chrisanderson is infamous around these parts
I hace a 99 c2 cab with 37K on the clock and full Porsche service history. Checked fluids at the weekend and water was in the oil and vica versa. Towed to Porsche today - has anyone seen this and does anyone rate my chances of getting Porsche to contribute?
Finally, suggestions for engine replacement strategy?
thanks
Chris
Old Sep 21, 2006 | 12:27 PM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
is the car not working?
Old Sep 21, 2006 | 01:37 PM
The dealer has just phoned to say it will need a whole new engine. They are investigating the root cause of the failure.
Old Sep 21, 2006 | 01:42 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
If this is not covered under warranty, I personnaly, would remove the heads and find out myself what when wrong. If it turns out that the block is cracked, leaks, bad oil seperator or a sleeve slipped, you then have a legitamate beef with Porsche. Simply accepting Porsche's word that you need a new engine without them specifically identifying the reason for failure, would be a mistake IMO.
Old Sep 21, 2006 | 03:08 PM
MexicoBlue's Avatar
MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !
GT700 while you're at it? Just a thought . . .
Old Sep 21, 2006 | 04:23 PM
angldrkns9's Avatar
can they make a NA 996 into a GT700?
Old Sep 21, 2006 | 05:27 PM
MUSTGOFAST's Avatar
MUSTGOFAST is a jewel in the roughMUSTGOFAST is a jewel in the roughMUSTGOFAST is a jewel in the roughMUSTGOFAST is a jewel in the rough
According to my experience, under warranty Porsche doesnt allow the dealers to work on the internals of the engines. My engine failed at 55k miles, Porsche protocol would be to replace not repair the engine. Easycare, my extended warranty company, paid to have the dealer open the engine to determine the point of failure. The verdict was detonation in the cylinder that caused the damage. Easycare denied the claim and said that they do not cover failure due to detonation. Porsche argued how can you say if detonation is the cause or effect of the damage. Finally, PNA stepped in and paid for a lion's share of the new engine replacement cost. I paid roughly $2500. Porsche have convinced me that, they think it is worth it to keep a customer buying Porsches for life than worry about a measly $10k. In comparison of course. Goodluck with your car Chris!
Old Sep 21, 2006 | 06:26 PM
The problem with Porsche simply replacing the engine, it prevents the owner from knowing what happened to break it. Unless it was under warranty, I would tear it apart, or have someone else tear it apart to find out why. You can always get a replacement engine afterwards, but wouldn't it be nice to know the reason it failed and to maybe use this info to get Porsche to replace it at a discount or for free if it's a major componant failure?
Old Sep 21, 2006 | 08:38 PM
MUSTGOFAST's Avatar
Yes it would. I'm assuming you dont have warranty coverage. Best of luck with your process of replacement/repair. I dont have any experience with repairing/replacing an engine outside of the warranty or dealer side. I'm sure there are many options. Please keep us posted, as this will be useful info for many. Thanks!
Old Sep 21, 2006 | 08:52 PM
Thanks for the comments guys, the service rep at Porsche has escalated this to Porsche NA. Lets see what the nice men at Porsche NA have to say! Any work I should do while they are at this level? New Clutch?, sports exhausts? Does the RMS get replaced with the engine or is that the gearbox?
Chris
Old Sep 21, 2006 | 09:50 PM
Brian Haske's Avatar
Brian Haske is infamous around these partsBrian Haske is infamous around these parts
Definately, without a doubt, replace the rms with updated flywheel bolts, then its covered by porsche for 2 years, when.. cough cough, if, it leaks again. Sports exhaust, clutch, etc are all things you can do to save labor costs while its apart.
Old Sep 21, 2006 | 10:40 PM
Chris
Your replacement engine will come with it's own RMS.
Old Sep 27, 2006 | 04:57 PM
The nice men at Porsche North America have offered me 50% of the new engine, anybody got a better deal from them??? or should I just grab it with both hands!!!
Chris
Old Sep 27, 2006 | 05:08 PM
TraderHal's Avatar
TraderHal is a glorious beacon of lightTraderHal is a glorious beacon of lightTraderHal is a glorious beacon of lightTraderHal is a glorious beacon of lightTraderHal is a glorious beacon of light
how much does an engine replacement run?
Old Sep 27, 2006 | 05:10 PM
MUSTGOFAST's Avatar
I paid $2500.....The % just depends on what they charge to replace the engine. What are they charging for the replacement? I bet it has a lot to do with how far out of your warranty you are. Goodluck with it!
