Front blinker dead. New headlight assembly?
Old Jan 13, 2007 | 11:40 AM
John Romano's Avatar
John Romano is infamous around these parts
Hey guys...
I have a new problem. Can anyone confirm this? My left front turn signal is out. The dash indicator blinks rapidly. I asked my mechanic to change the bulb yesterday while I had the oil changed. He changed the bulb and it still didn’t work. He removed the headlight assembly and tested the connections. He found that the problem is inside the headlight unit, which, he says, cannot be opened. Do I actually have to replace the entire headlight assembly to get a $2.00 bulb to blink?
Old Jan 13, 2007 | 11:56 AM
Sharp's Avatar
Sharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud of
just need to top up the blinker fluid!!!
sorry couldn't resist...
Old Jan 13, 2007 | 12:07 PM
HAAAAA!!! Yes, with electric blue Kool-Aid, right?
Old Jan 15, 2007 | 10:53 PM
skibum's Avatar
skibum has much to be proud ofskibum has much to be proud ofskibum has much to be proud ofskibum has much to be proud ofskibum has much to be proud ofskibum has much to be proud ofskibum has much to be proud ofskibum has much to be proud of
Before you buy a whole assembly I woild try to open it. It's a fairly common practice among the honda community to bake the headlight in the oven for about 10 min. This softens the glue and will allow you to pull it apart.
Old Jan 17, 2007 | 02:20 AM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
I wouldn't take the chance on the oven bake.... I used to re-work FD3s tail lights and the best thing to do is use a heat-gun so you can control the temps.... "IF" you're going to chance it. I would first try to swap a couple of new bulbs or plug it into someone elses harness. It might be a harness which is cheaper to replace than a headlight.
-Eli
Old Jan 17, 2007 | 04:02 AM
Redridge's Avatar
I would also check the rest of all the bulbs. In my muscle car days. if 2 or more bulbs goes, it throws out the empedance of the whole circuit and can cause uneven blinking. Also check out if there is any grounding issues (wire touching metal, loose wire, bad connection), not only at the problem area but the rest of the electrical harness.
Old Jan 17, 2007 | 10:18 AM
Thanks guys. The harness was tested, as well as the bulbs. We narrowed it down to inside the headlight case. I imagine there is a circuit board or something in there that has a loose connection? We ruled out everything outside the case.
Old Jan 18, 2007 | 11:25 AM
xdream's Avatar
xdream is infamous around these parts
John, had the same thing happen to me and it turned out that one of the pin on the headlight assy was bent and not lined up with the socket. Took me awhile to figure that out. Check the connector in the HL Assy.
Old Jan 18, 2007 | 12:12 PM
Or you can also take it to an electrical guy, they might only charge you a few bucks to test and make the necessary repairs. . .
Good Luck,
-Eli
Old Jan 18, 2007 | 12:21 PM
Tool Pants's Avatar
Tool Pants is infamous around these parts
Find a local owner with your style headlight and swap to see if it is really the headlight.
Old Jan 19, 2007 | 01:37 AM
ChromeHearts's Avatar
ChromeHearts is infamous around these parts
Good Luck,
-Eli
thats a good idea, have some electronics shop test the connectors and resistors, resistance, ohms, all that good stuff, and circuit boards to narrow down the problem. If its electrical it probably can be replaced/repaired fairly reasonably. Circuits and those things are pretty inexpensive. Or have an electrical engineer look at it - if you know of any?
Old Jan 23, 2007 | 02:47 PM
I had everything tested. The pins are straight. Everything that could be done outside the assembly was done. The problem lies somewhere inside the enclosure. It has to be opened. Has anyone ever split one of these things open?
Old Jan 23, 2007 | 03:02 PM
MAD CAT's Avatar
MAD CAT is infamous around these parts
I had the exact same problem... I replaced the light bulb holder/socket and is all good , around $20 for the parts.
Old Jan 23, 2007 | 04:08 PM
C4C_leon's Avatar
C4C_leon is infamous around these parts
I had the same thing.
Changed bulbs, no joy.
Took the car to the dealer for oil change and asked them to look into it too.
The changed the light assy (fortunateluy under warranty)
Old Jan 25, 2007 | 11:22 AM
Cool. I'll try that for $20. Do you by any chance have a part number?
Thanks!!
