Storage bin handle removal.
Old Mar 25, 2004 | 12:39 PM
anythingbuttime's Avatar
anythingbuttime is infamous around these parts
How do I remove the small silver lift handle on the door starage bins? Thanks in advance.
Old Mar 25, 2004 | 12:41 PM
msindi's Avatar
Im not sure if these come out...
Old Mar 25, 2004 | 12:55 PM
dpblessing's Avatar
senior member
dpblessing is infamous around these parts
I I recall correctly, they just pop / pry out.
I have an extra set at home and if I remember (always the challange) I will double check this evening.
Old Mar 25, 2004 | 03:28 PM
L.A. Cab's Avatar
L.A. Cab is infamous around these parts
They do pop out, 1st you need to remove the cover (undo screws) then you push/squeeze the plastic clip on the back that holds the silver lift handle. I have heard others say that you can pry it out w/o removing the cover, but I was afraid that i would damage the lid trying...
Hope this helps....
Old Mar 25, 2004 | 05:29 PM
Turbo Racer's Avatar
Turbo Racer is infamous around these parts
They do NOT pop out unless you want to pop out the 14 bolts that hold them in place. I posted a how to on renntech.org for this. I swapped my leather for aluminum. You will need small hands and a torx 10 socket with a 90 deg angle to remove some of the bolts. If you hit any resistance, check and make sure that you removed all the bolts. There is a plastic phillips screw that sits in the centre of the door panel that sometimes causes a divot or scratch in the center of the armrest. I removed mine without sequalae. The horseshoe mouldingt that travel between the door release and the arm rest/storage bin do pop right out. I hope this is helpful. good luck in your endeavor.
regards
Old Mar 25, 2004 | 09:49 PM
mozhacker's Avatar
mozhacker is infamous around these parts
what silver lift handle? or for that matter, any lift handle? is this something only some 996s have/had?
I have door storage bins but it seems to just directly rotate up with a small plastic bump/wedge picece stuck on the storage bin lid.
Old Mar 25, 2004 | 10:09 PM
dpblessing's Avatar
senior member
Mozhacker... the bump = the handle
Old Mar 25, 2004 | 10:17 PM
mozhacker's Avatar
ok, i have a handle too then
but mine is just a plastic black piece, or hard leather maybe.
PV=nRT.
Sep 9, 2022 06:06 PM
PelicanParts.com
996 Vendor Classifieds
Sep 11, 2015 12:08 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Sep 11, 2015 12:06 PM
yumaverick
Sep 2, 2015 03:48 PM
