2002 C2 coupe - door window not closing properly, adjustment?
Old May 4, 2007 | 01:45 AM
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
There may be a thread on this here but I could not find it-
Basically, every 3rd or 4th close of the passenger door on my coupe does not seat the window properly in the channel, it stays popped outside of the rubber top trim.
It seems that the window is not dropping down fast enough before the door closes, and I have to re-open the door once or twice to get it to close with the correct timing.
Is this a switch adjustment? My car only has 29k miles on it. any help would be appreciated.
i also tried rolling the window up/down several times to hopefully re-initialize things, the problem is intermittent but consistent.
Old May 4, 2007 | 08:53 AM
p0rsch3's Avatar
ah hah! I see exactly what is going on now. Was outside messing with it for a bit.
It is supposed to drop 1/2 inch on door open. It is only dropping 1/4 inch sometimes, far enough to open the car door but causes binding when closing the car door.
if I open the door and it drops 1/4 inch, I can push the glass down the remaining 1/4 inch but there is some resistance, almost like something is not lubricated and allowing the glass to drop the full 1/2 inch.
Thoughts on what this might be before I go ripping the door apart?
Old May 4, 2007 | 09:53 AM
p0rsch3's Avatar
now that is interesting...
I worked the drop up and down with my hand a few times (pulled the glass up and pushed down several times the 1/2 inch travel), and now it seems to work fine.
I opened / closed the door various ways trying to trip it up and it is ok. So maybe it was just sticky from not being used much... lubrication might be in order.
Will see if it stays ok or starts giving me problems again- Thanks to Loren over at renntech for his help.
Old May 4, 2007 | 10:21 AM
Dev911's Avatar
Dev911 is just really niceDev911 is just really niceDev911 is just really niceDev911 is just really nice
Its the switch. Need new one. Old story. Happens to the best.
Old May 4, 2007 | 10:22 AM
PeterK's Avatar
PeterK is infamous around these parts
Need a window motor switch. Prolly looking at $300-500 for parts labor.
Old May 4, 2007 | 10:42 AM
p0rsch3's Avatar
Thanks- is the motor switch separate from the door open (located on handle) switch or the door close switch (located on door latch)?
The switches seem to operate ok, it is the length of the drop that is suspect. At times it did not drop far enough, although it did in fact drop / go up every time.
Old May 9, 2007 | 06:29 PM
Dscott's Avatar
Dscott is infamous around these parts
Since you could move the glass up and down 1/2 inch it sound more like the window regulator is failing. The regulator is the cable assembly inside the door that the window motor drives in order to move the window up and down. Over time and with use the cables get loose. There is no adjustment, just replace. Takes an hour or two as a DIY. Regulator cost about $200 and is specific side-to-side.
Old May 9, 2007 | 07:12 PM
bruceinmiami's Avatar
bruceinmiami is infamous around these parts
do post your results upon fixing this problem. i fear my drivers window is not sealing properly.
Old May 9, 2007 | 08:52 PM
p0rsch3's Avatar
Dscott- Thanks for the info. I'm fine with taking the assembly apart to replace it, and yeah considering the 1/2" play that makes sense.
I will get to it in a couple of weeks (my time is way limited lately, new biz and all..) and will definitely post the results.
Sucks tho- The car only has 29k miles on it and the passenger seat looks practically un-sat in (guess the prev owner wasn't getting much action...lol) -Not much time or wear on the parts, really!
Old May 10, 2007 | 07:14 AM
Dscott's Avatar
Old May 10, 2007 | 07:49 AM
RocC4S's Avatar
RocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant future
Did you recently have your battery disconnected? The window may not be synchronized any more and the motor has lost its hall effect signal of where it is supposed to be. I had this happen to me before. Hold the window switch down for a few seconds all the way down and then all the way up, this usually cures it. Goes the same for the other window and sunroof too. Good luck with the gremlins....
Old May 10, 2007 | 07:57 AM
zdr2k's Avatar
zdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud of
DIY for a boxster.....close enough i would think.
http://www.bombaydigital.com/boxster/projects/window/
Old May 10, 2007 | 12:18 PM
p0rsch3's Avatar
RocC4S - yep, tried the re-synching, no avail. It's an intermittent problem, sometimes it's fine sometime's its not.
Old May 10, 2007 | 12:19 PM
p0rsch3's Avatar
thanks for the links guys-
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
richard2966
Bentley
Aug 22, 2015 03:33 PM
Aug 19, 2015 06:35 PM
