How do I safely drill a hole in alcantara?
I need to make a 1/2" hole in my overhead lighting console (coupe) to install a switch up there. The console is plastic covered in alcantara, and I've been told it rips very easily when you drill into it.
Any tips?
Any tips?
I would razor blade a small X first, then lightly peel away the leather so the drill bit won't hit it. I would also drill the hole in reverse, less likely to catch the leather and twist it up into the bit.
Originally Posted by apex177
...you forgot the channelocks. The only two tools you need in the box
-Cheers!
-Cheers!
Thanks to all the useful replies to my post (yeah, right), I was able to drill the hole I needed neatly and without any damage. I started with a very small hole, then a slightly larger one. To get the hole to 1/2" diameter, I proceeded to widen it with a V-shaped hasp, using a slow speed on the drill and stopping to trim off the edge of the material with a razor blade.
