996tt Knowledge Base
Knowledge Base Thread - Do NOT create new threads..post in this one
Rating: Thread Rating: 2 votes, 3.00 average.
Old Mar 9, 2011 | 12:48 AM
  #31
Talisman013's Avatar
Talisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond repute
Old May 28, 2011 | 04:35 PM
  #32
VAGscum's Avatar
Before cat Oxygen sensors
Porsche PN: 996 606 128 00 $126-$250
Bosch equivelant PN: 17044 $76 amazon or $96 Autozone
Link: https://www.6speedonline.com/forums/...ml#post3217943
Old May 28, 2011 | 05:19 PM
  #33
VAGscum's Avatar
Post cat Oxygen sensors:
Porsche PN: 99660613801 $165-$250
Bosche PN: 16205 $100 amazon or $126 Autozone
Old Aug 3, 2011 | 01:24 PM
  #34
vividracing's Avatar
Old Aug 3, 2011 | 01:30 PM
  #35
Agency Power Short Shifter Installation (on a 987 but basically the same minus the shift ****/ boot removal)
Old Aug 4, 2011 | 02:25 PM
  #36
996 Turbo EvoMS Intake - Air Filter Maintenance
#TeamAIM
Old Sep 15, 2011 | 05:38 PM
  #37
VAGscum's Avatar
Filling a failed transmission mount with 3m Window Weld:
https://www.6speedonline.com/forums/...ion-mount.html
FYI: This is a Polyurethane that is intended for dampening of windows. It rates at ~60A hardness. Here is the data sheet on it:
http://www.google.com/url?sa=t&sourc...W_1Krr6c67YGcg
Old Sep 20, 2011 | 08:50 PM
  #38
VAGscum's Avatar
DIY Front Differential Repair:
https://www.6speedonline.com/forums/...ml#post2617071
FYI about LSD(not the Timothy Leary LSD):
https://www.6speedonline.com/forums/...sd-buster.html
Old Oct 5, 2011 | 07:25 PM
  #39
VAGscum's Avatar
DIY RS Motor Mount install:
https://www.6speedonline.com/forums/...ml#post3332488
Props to Scottslaw
Old Oct 30, 2011 | 06:22 PM
  #40
VAGscum's Avatar
DIY Alternator replacement w/ Pictures:
https://www.6speedonline.com/forums/...-pictures.html
Props to Slider for a great post!
Old Nov 3, 2011 | 08:12 PM
  #41
VAGscum's Avatar
Coilover install DIY w/ pictures!!!:
https://www.6speedonline.com/forums/...read-pics.html
Huge props to Scottslaw for the contribution!!!
Old Nov 11, 2011 | 07:17 PM
  #42
VAGscum's Avatar
Headlight switch replacement DIY:
https://www.6speedonline.com/forums/...e-replace.html
Huge props to smistry007 for a great DIY w/ pics
Old Dec 10, 2011 | 05:05 PM
  #43
NBTBRV8's Avatar
NBTBRV8 is just really niceNBTBRV8 is just really niceNBTBRV8 is just really niceNBTBRV8 is just really niceNBTBRV8 is just really nice
Ignition lock housing replacement for when the key is hard to remove from the lock:
https://www.6speedonline.com/forums/...ml#post3395412
Old Dec 14, 2011 | 05:58 PM
  #44
VAGscum's Avatar
RS LWFW conversion parts list
***Edited to correct pressure plate bolt part number***
Clutch guide tube: 950 116 813 30
Guide tube screws: 900 270 055 02 (2 ea)
Starter ring gear: 964 114 143 31
Throw out bearing: 944 116 080 01
Flywheel bolts: 928 102 151 01 (9 ea)
Flywheel: 964 102 239 31
Pilot Bearing: 931 102 111 00
Pressure plate bolts: 900 067 103 02 (9 ea)
Note:
The following is added for the addition of the lightweight RS pulley. Porsche released a TSB on the 997 GT3 related to fix an issue with this stock weight pulley coming off when the lightweight flywheel is installed. So far I have not personally heard of this happening on the 996TT, but I personally would at least re torque and loctite the pulley bolts for good measure.
996 102 017 95 Crank pulley
999 025 174 02 Washer
996 102 550 80 Bolt
Old Dec 29, 2011 | 06:09 PM
  #45
02turbo996's Avatar
02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future02turbo996 has a brilliant future
Modding Transmission case for GT2 slave conversion.
https://www.6speedonline.com/forums/...ml#post3412313
You have already rated this thread Rating: Thread Rating: 2 votes, 3.00 average.
