Tire Pressure on 20's?
Old May 12, 2008 | 09:28 AM
slykmr's Avatar
slykmr is infamous around these parts
What tire pressure are you guys with 20's running? Is around ~40 about right? TIA.
Old May 14, 2008 | 09:41 AM
freightmover21's Avatar
freightmover21 is infamous around these parts
i am doing 42/
Old May 14, 2008 | 09:44 AM
your porsche dealer can do it for you/////...they did it for me
Old May 14, 2008 | 09:57 AM
HUMMM 3's Avatar
HUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud ofHUMMM 3 has much to be proud of
Shouldn't be much different than the 19" stock pressures, which you could use as a starting point. Front pressures should be lower than the rear. Track pressures are a whole different matter.
Old May 14, 2008 | 11:08 AM
ANUBIS's Avatar
ANUBIS is infamous around these parts
I Have 2.4 And 2.8 On Rear
Old May 14, 2008 | 11:45 AM
ALPINE_997's Avatar
ALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to behold
I run 36/42
Old May 14, 2008 | 03:02 PM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
I run 38 front and 42 rear.
Old May 14, 2008 | 03:06 PM
ALPINE_997's Avatar
GotBoost - I am going to be like timeattack...Prove it.. Let's see your read out
Old May 14, 2008 | 03:15 PM
HotRodGuy's Avatar
depends on the tire............
Old May 14, 2008 | 03:25 PM
996TTDave's Avatar
996TTDave has a spectacular aura about996TTDave has a spectacular aura about996TTDave has a spectacular aura about
what is so difficult by doing it yourself? and you should check your pressure every 2 weeks or so, if you're low are you going to drive to the dealership just for them to do it? by a tire pressure gauge and drive to a gas station or buy a compressor and do it at home...
Old May 14, 2008 | 04:00 PM
HotRodGuy's Avatar
yeap, it's amazing how many people do not check their tire pressures regularly. It's much worse then people checking their oil.
It's not even just the pressure you should be checking...you should be looking for irregular wear etc. I can't tell you how many times I saw customers who would come in with cords exposed and try to blame the tire......WHEN WAS THE LAST TIME YOU EVEN INSPECTED IT!!!
You should check your pressure atleast 1x a month...check for wear every 1,000 miles.....and check your oil level every other fill up!!
Old May 14, 2008 | 04:19 PM
ALPINE_997's Avatar
I check once a week. Since I can almost throw a rock at the Discount Tire store I run it over there all the time.
Old May 14, 2008 | 05:34 PM
GotBoost?'s Avatar
Ah man... You caught me......
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
The Oss
Aug 24, 2015 08:19 PM
