Guess what the Michelin Man had for Lunch ?
Old Sep 4, 2008 | 08:45 PM
GEE-BEE's Avatar
GEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of lightGEE-BEE is a glorious beacon of light
Angry Guess what the Michelin Man had for Lunch ?
Look what I found in my RH Rear Tire....
A small CO2 Cylinder...
Less than 3k miles on it...
Gee-Bee
Old Sep 4, 2008 | 08:50 PM
carlover08's Avatar
carlover08 is infamous around these parts
oh wow that is nuts do you have tire road hazard warranty?
Old Sep 4, 2008 | 10:49 PM
TT Surgeon's Avatar
Just get a new pr of rears.
Old Sep 4, 2008 | 11:10 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
whoa, never seen that before...
Old Sep 4, 2008 | 11:50 PM
muerdeme's Avatar
muerdeme is a name known to allmuerdeme is a name known to allmuerdeme is a name known to allmuerdeme is a name known to allmuerdeme is a name known to allmuerdeme is a name known to all
I see the CO2 cylinder imbededed...what is going on down and to the left one inch???
Old Sep 4, 2008 | 11:51 PM
muerdeme's Avatar
Clarification...talking down and to the left 1 inch in first picture...
Old Sep 5, 2008 | 07:59 AM
GEE-BEE's Avatar
I was making a left turn at a stop light , sensor went off in a few seconds and I stopped after that.....
Put it on a flat bed home....
Note: Always have a small phillips to remove your front lip before you put it on a flatbed for towing...
I removed the two Tork and use phillips scres for the two sides on the Lip
Gee-Bee
If I didnt have any Bad luck , I wouldnt have any at All !
Old Sep 5, 2008 | 08:05 AM
fastdreams's Avatar
fastdreams has a spectacular aura aboutfastdreams has a spectacular aura about
That's the damage the cylinder made. GEE-BEE had already pried it out of the tire and set it down on the tire for the picture. If you look in the other two pictures you can see the cylinder is still embedded, and the anomaly you point out is not there.
Old Sep 5, 2008 | 09:56 AM
Josh/AWE's Avatar
Wow. That is a first...
Old Sep 5, 2008 | 10:43 AM
WheelEnhancement's Avatar
WheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant futureWheelEnhancement has a brilliant future
I have pulled some weird stuff out of tires over the years... needle nose pliers (embedded itself in the wheel) , part of a hack saw blade frame, a bullet (also went into the wheel), nails and screws head first, keys, an allen wrench, a big hunk of rebar (also through the wheel), etc...
Old Sep 8, 2008 | 08:38 AM
PIXC55's Avatar
PIXC55 is infamous around these parts
I FEEL you ,im the king of getting flats with new tires. But im lucky!!! they always hit the sidewall, which forces me to get new tires.
Fadi
Aug 17, 2018 05:16 PM
Feelgood MD
Mar 24, 2016 09:35 AM
alpha motoring
Sep 12, 2015 10:53 AM
alpha motoring
