Car gurgling and then dying.
Old Feb 13, 2009 | 10:02 PM
Neeeenja's Avatar
Neeeenja is a jewel in the roughNeeeenja is a jewel in the roughNeeeenja is a jewel in the rough
Got my car back, still need to align it after all the suspesnion work. But it seems to gurgle and the engine dies everytime im in neutral. This started happening after I put on my evoms headers on although my bodyshop said it was a leak so they replaced some small part on the headers which they said made it fine. Now I put on the Plenum and it even worse now, really hard to keep the engine alive. Any ideas on whats going on?
Old Feb 13, 2009 | 10:09 PM
TT Surgeon's Avatar
I think the plenum install might be at fault, check all the vacuum lines and hoses.
Old Feb 13, 2009 | 10:41 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
boost hose?
Old Feb 13, 2009 | 11:42 PM
G-forceTarga4S's Avatar
G-forceTarga4S has a brilliant futureG-forceTarga4S has a brilliant futureG-forceTarga4S has a brilliant futureG-forceTarga4S has a brilliant futureG-forceTarga4S has a brilliant futureG-forceTarga4S has a brilliant futureG-forceTarga4S has a brilliant futureG-forceTarga4S has a brilliant futureG-forceTarga4S has a brilliant futureG-forceTarga4S has a brilliant futureG-forceTarga4S has a brilliant future
Do you have a light weight fly-wheel? That can make the car idle rough & seem "out of sorts" at low idle.
Old Feb 14, 2009 | 09:57 PM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
Sonds like a bad plenum install. Have them re-check the hoses and clamps for any leaks. Make sure they tighten the bolts down completely on the headers also.
Old Feb 15, 2009 | 06:24 AM
landjet's Avatar
I know this is not related to your new mods but gurgling is usually associated with the oil system and tank. Could you be having low oil pressure? Just a thought.
Old Feb 15, 2009 | 06:39 AM
SRatha's Avatar
SRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud of
Did you install it yourself bro? Try and fit back the old plenum and see if it gets better and go from there. From my understanding, if you have the header leak, it is not the reason why the engine is shutting.
Question, when you are in neutral, does that mean when you depress the clutch? or when you put it 'between the gears'?
Old Feb 15, 2009 | 10:36 AM
Neeeenja's Avatar
its a competiton plenum from BBI so does that mean the ECU must be put it to make the car function properly?
Sratha No I didnt intall it myself I went to a local body shop Advanced motor sports. Any time Im in neutral it will gurgle and then the engine will die.
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
gulf gt
Aug 27, 2015 10:27 AM
Aug 21, 2015 09:56 AM
