5 mm oem spacers
Old Feb 15, 2009 | 10:59 PM
cgng30's Avatar
cgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to beholdcgng30 is a splendid one to behold
5 mm oem spacers
I have stock turbo wheels and i have the oem 5 mm spacers, with long bolts that i had on my 997 c2. will these work on the stock turbo wheels. i am not clear with the tech equipment notes for the spacers for turbo stock wheel application. or do i have to use 5 in front and 17 in rear.
i have seen post where people have different sizes, need advice if i can reuse the oem spacers or sell them
Old Feb 17, 2009 | 11:38 AM
cgng30's Avatar
vow 55 views and no response
Old Feb 17, 2009 | 11:42 AM
sharkster's Avatar
do the bolts say "GT" on them? If so then yes (GT3, GT2, RS etc..).
Old Feb 17, 2009 | 04:18 PM
cgng30's Avatar
thanks i will check the bolts, but my question really is will 5 mm on all four corners ok on stock turbo wheels
Old Feb 17, 2009 | 04:19 PM
sharkster's Avatar
On stock ride height? Should still be fine 5mm is very small.
Old Feb 17, 2009 | 10:02 PM
cgng30's Avatar
ok sharkster
the bolts do say gt on them. ( i have a turbo though) it was a 5mm kit i bought from porsche. so i wont have any issues with these on the stock turbo wheels/pccb then?
oh i will be lowering the car by ~ 20 mm
thanks again
Old Feb 17, 2009 | 10:15 PM
sharkster's Avatar
ok sharkster
thanks again
Hi Ronnie,
No that's perfect.. The bolts are the longer ones (with GT on them) and especially if you are lowering the car you'll be great with those and the 5mm spacer kit.
Old Feb 19, 2009 | 10:05 AM
cgng30's Avatar
Hi Ronnie,
great, i guess i dont have to sell my spacer kit . may i ask why it would be bettter with the spacers especially if i am lowering the car? i am assuming the wheels get tucked in when you lower it?
Old Feb 19, 2009 | 10:46 AM
TT Surgeon's Avatar
No, you will be fine with that setup.
cnebrask
Oct 3, 2024 08:19 PM
007 Vantage
Sep 4, 2015 06:55 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
