BMC Air Filter, Need help please
Does anyone have any instructions on how to replace the Stock Air Filter? Sorry i am not much of a mechanic. any instructions, pictures will help.
how to remove the airbox? that is really what i am trying to figure out.
I just finished installing it bud, I am getting ready to go out and drive the car a bit. Remember, I got bigger VTG's, ECU, Exhaust... so the filter is going to be one more thing to feel out. I will let you know.
Honestly, I do feel a difference. now with more air in, the rpm's are climbing faster and easier, the car just is breathing better period. more power needs cooler, more air I wish i have a way to do a dyno comparison, maybe the next time I hit Gilbert AZ I will
But again, the car has a ton of power, you feel them a lot after 5400rpm too. I have to run it a bit more and will see.
My BMC already 10000 kms and 2 years since I install it.
Should I clean and re oil it? I heard K n N filter can go up to 50000 kms without cleaning, also the stock paper filter can go 30000kms.
Is the BMC oil filter element getting dry after 2 years?
Two years, two months... it doesn't really matter, what matters is the conditions you drive in and how quickly the filter gets dirty. go on the site and check it out.
Very few waters will get into the airbox and the filter is standing back not flat on,so there is really no chance to suck water into the filter.Even it suck a bit,it is a long way from the intake tube to the turbo inlet.Heat will dry it through the way.Nothing to worry about really.
