HRE's P40 20" Rubbing wheel housing plastic - Help
Old Aug 10, 2009 | 12:37 PM
Kuwait997's Avatar
Kuwait997 is a splendid one to beholdKuwait997 is a splendid one to beholdKuwait997 is a splendid one to beholdKuwait997 is a splendid one to beholdKuwait997 is a splendid one to beholdKuwait997 is a splendid one to beholdKuwait997 is a splendid one to behold
Hello friends,
Was installing HRE's P40's today on my 997 TT, i have the PSS10's and the car was aligned to GT2 specs. I think it's been lowered -20 mm. The problem is that the wheel fit all around however when you turn the steering about 40% either left or right it hits the wheel housing (the black plastic above the wheel and to the sides).
I was told that the alignment if returned to OEM 997 TT spec it wouldn't rub. can anyone confirm. anyone here with those rims in 20" size on a 997 TT with advice. thanks!
Old Aug 10, 2009 | 02:12 PM
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
I can tell you that i have the same set up 20" p40 with 20mm drop on B16 pasm with no rubbing at all ,i did have it alligned but not to GT3 specs.
Old Aug 10, 2009 | 03:38 PM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
That's odd. Who did you order the wheels through? I hope it gets figured out
Edwin
Old Aug 10, 2009 | 04:58 PM
NeilM's Avatar
NeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond repute
potentially the wrong offset? Never hear of 20' P40s rubbing no matter at what height.
Old Aug 11, 2009 | 01:51 AM
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
I don't think the alignment is the problems. It's either wider wheel or wrong offset I could be wrong tho
Old Aug 11, 2009 | 11:58 AM
WheelB's Avatar
Site Sponsor
WheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant future
what tires did you get that might be your problem .. HRE makes one offset for 997TT on the mono blocks ..we have done all from stock height to lowered 30mm+ no rubbing ever .. post full specs see if we can help you out
Wheels Boutique // 786 249 0127 // Sales@wheelsboutique.com
Follow us on YouTube: www.youtube.com/user/WheelsBoutique
Largest HRE Dealer In The World / Largest ANRKY Dealer / BBS Premium Dealer / TechArt Premium Dealer / Vorsteiner / Rotiform / Akrapovic / iPE / Novitec / Brabus / AC Schnitzer / Mansory / Brembo / RENNTech / Weistec / Tubi / Hamman / KW / H&R and tons more.
Old Aug 11, 2009 | 12:02 PM
D1911's Avatar
D1911 is a name known to allD1911 is a name known to allD1911 is a name known to allD1911 is a name known to allD1911 is a name known to allD1911 is a name known to all
Post your wheel specs and tire size.
Old Aug 12, 2009 | 09:35 AM
vividracing's Avatar
Its not the wrong offset. The wheels are 997TT P40 20x9 and 20x12. The tires are 245/30/20 and 325/25/20 Michelin PS2. We sold them both the coilovers and wheels. As TWTURBO said, he has the same setup. In fact bought from us too. The shop you are using needs to figure out the alignment and ride height setup. Great customer, ****ty install shop.
If anyone has any suggestions, please advise...
Old Aug 12, 2009 | 11:01 AM
TT Surgeon's Avatar
I don't have 20s, but my camber is now at -2.0 in the front lowered -20mm, no rubbing at all. Your shop needs to figure it out.
Old Aug 12, 2009 | 11:29 AM
We have done some discussion and here is what I think happened....
The customer said the wheel was pushed forward and at barely turning the wheel was rubbing the fender liner. His picture he sent to me showed this. After discussing the setup, since the front strut top is angled, it is possible that the strut top has been rotated causing different castor and then them trying to align the car around that.
See the top of this Bilstein shock here -
Old Aug 12, 2009 | 11:55 AM
Here is how the shock should look -
If the angle of the Bilstein piece under the rubber strut top is reverse, it would put to much castor on the wheel pushing it forward into the fender liner. I think we found the install problem. Lets see if they can correct it.
Old Aug 12, 2009 | 11:57 AM
NeilM's Avatar
aha! good work sleuthing it out.
Old Aug 12, 2009 | 11:59 AM
Now at least we have something searchable and easy to reference for others.
Old Aug 12, 2009 | 02:14 PM
KA 997TT's Avatar
KA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond repute
I know at least 100 People running this set up, PSS10's and HRE P40 20's it is like the most popular set up on this forum. the bilsteins needs to be lowered at least 15-20mm to work properly and your alignment has to be done right. front wheel rubbing would not be caused by camber adjustment but your caster and toe settings will be way off. if you go to a decent shop you will get proper results or even better have the car corner balanced.
I am on my third coilover kit and have had 20's since the second week i bought my car, i drive it probably a lot harsher than you will ever drive your car and no rubbing. hope this helps.
oufan2929
Nov 8, 2015 08:26 PM
Zero911
Aug 24, 2015 06:51 PM
ModBargains
Aug 20, 2015 12:28 PM
