Engine Fan Failure !!!
Old Sep 29, 2009 | 05:37 PM
Samra997's Avatar
Samra997 is infamous around these parts
Hey guys I would like to know if this is something normal or its just my luck,
A couple of days ago i replaced the OEM air intake for the Fabspeed one. And a day after that the fan for the engine compartment which is on the lid failed.
Would appreciate any advice if its because of the Intake or not
Thanks,
Samir
Old Sep 29, 2009 | 07:09 PM
KA 997TT's Avatar
KA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond repute
Did you do the installation yourself? Is it possible that you may have damaged something in the process?
I always go to the dealer when I run into issues with my car.
Old Sep 29, 2009 | 07:48 PM
Porsche997TT's Avatar
Porsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to behold
Seems to be your luck....Unless the FabSpeed intake retricts airflow to the fan, etc.. but I doubt that.
Whats a new one run? $150+/-
Old Oct 1, 2009 | 10:55 AM
bbywu's Avatar
1. How do you know that your engine fan failed? It is not always on, and does not give a CE light when it's down.
2. Is your engine bay light on? The fan and light share the same fuse.
3. Is the fan wiring harness plugged in? It uses a locking interface that can come disconnected.
The wiring harness for the engine deck lid fan goes nowhere near the intake system. I doubt they are related. I'd check for the things I mentioned above.
Old Oct 1, 2009 | 01:41 PM
ed997tt's Avatar
ed997tt is a splendid one to beholded997tt is a splendid one to beholded997tt is a splendid one to beholded997tt is a splendid one to beholded997tt is a splendid one to beholded997tt is a splendid one to beholded997tt is a splendid one to behold
+1. have on my car as well and no issues, a quality piece. As has been suggested, I would check the items mentioned.
Originally Posted by my997turbo
I have the Fabspeed intake on my 997 turbo, and it works fine. It's probably is just the fan acting up, or bumped against, this product is not a bad one, excellent quality!
Old Oct 1, 2009 | 03:24 PM
landjet's Avatar
I think this should cover it. If the fan has failed it's only 3 bolts and a connector to change it. Very easy.
Old Oct 4, 2009 | 06:56 AM
handdoc's Avatar
handdoc is infamous around these parts
i doubt it is a related issue as well, just bad luck and crappy timing
Old Oct 5, 2009 | 04:28 PM
SoCalCFP's Avatar
SoCalCFP is infamous around these parts
my fan failed as well. covered under warranty.
Old Oct 5, 2009 | 06:58 PM
FSU-997TT's Avatar
FSU-997TT is infamous around these parts
There is also a relay associated with the fan that has been know to fail.....
nlakind
Nov 6, 2015 10:15 AM
saline
Oct 7, 2015 07:29 AM
LiquidElephant
Aug 27, 2015 06:17 PM
ECS Tuning - VW
Aug 27, 2015 08:30 AM
bobolouie
Aug 26, 2015 12:02 PM
