Choosing a tuner? Choose Protomotive!
Old Jul 21, 2011 | 01:45 PM
  #181
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Originally Posted by milou
The maximum boost I could see on logs was 2550, when I installed a boost gauge I discovered that my boost goes well above that.
1st gear 1,2b
2nd 1,5
3rd 1,7
4th 1,7-1,8
I haven't had the chance do check 5th but I think it could be around 2
Is the 1.7-1.8 boost sustained or transient?
Old Jul 22, 2011 | 01:22 AM
  #182
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
Sorry Dave, I don't understand the question. I can get you a video soon
The gauge showed 1,2b on 1st gear and every gear change it was climbing by 0,2-0,3b.
Old Jul 22, 2011 | 01:24 AM
  #183
milou's Avatar
Originally Posted by Shadowman30
Bogg and K24F
Make sure to clean ur airfilters by gas/water/soap...that could effect ur results
I checked my BMC and it really looks very dirty, do you think this would affect the performance noticeably ?
Old Jul 22, 2011 | 03:07 AM
  #184
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
If you restrict the amount of air interring to the turbo's differently it will effect the power. The more air in the more fuel you can burn >>> more power
Old Jul 22, 2011 | 10:10 AM
  #185
TTdude's Avatar
Sorry Antonis. I mean does the boost stay at 1.7 bar or does it just spike to 1.7 bar and settle back down to 1.5 bar? Interesting finding. Thanks.
Old Jul 22, 2011 | 10:14 AM
  #186
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Yes I think, turbos engines love clean airfilters!
Even if the 997TT air filter has a great surface.
A little story:
In 1997 I had got a tuned 944Turbo (951X) which produced 290chp/400Nm.
When my (stock size) KN airfilter was clean I was hiting the revlimit in 5th (last gear, 295kph at the dashboard), when it was not, It was hard to touch 290 and impossible to hit the revlimit...
From this car I always have got 2 airfilters (BMC or KN): 1 in the car and 1 clean ready to exchange in the garage, I switch every 4/6 monthes and clean the one I bolt off.
Old Aug 20, 2011 | 09:32 AM
  #187
cosmokr's Avatar
cosmokr is infamous around these parts
Anyone with a non-Sports Crono and a flash know if after an aftermarket flash, can the Tuning companies enable these functions?
Old Aug 20, 2011 | 12:15 PM
  #188
TTdude's Avatar
If you want to enable all the functions Sport Chrono controls, I think you have to go to your dealer and install the SC kit. An aftermarket flash can give you "SportChrono" engine performance equal to a flashed SC option car.
Old Aug 20, 2011 | 12:28 PM
  #189
SpoolnV8's Avatar
SpoolnV8 is infamous around these parts
I just swapped to the GT2 Slave cylinder. Normal driving in Sport mode is so much easier. Before it was so jerky.
Old Aug 20, 2011 | 12:35 PM
  #190
TTdude's Avatar
Good to hear. I'm switching over as well. This sounds like one of those "must do" mods.
Old Aug 20, 2011 | 02:55 PM
  #191
milou's Avatar
Sorry Dave, I don't know how I missed this question
Yes it stays at 1,7 I think 5th gear is 1,8
Old Aug 20, 2011 | 03:35 PM
  #192
TTdude's Avatar
No worries. That's great that your boost holds. Do you think we are all probably overboosting with these modded vtgs?
Old Aug 20, 2011 | 03:39 PM
  #193
milou's Avatar
I have no idea, I was also very surprised to see that boost. Duraetrs only shows upto 2550 which I think is 1,5b I noticed the overboost after installing a boost based gauge. I was wondering if this s safe for the engine
Old Aug 20, 2011 | 03:44 PM
  #194
TTdude's Avatar
At least with the vtgs you have all the safety features in place whereas with an EBC, you disable some. Where did you install the pressure gauge? Any pics?
Old Aug 20, 2011 | 03:52 PM
  #195
milou's Avatar
Before installing the aquamist I used to run the AEM w/m which was boost based. I pulled the tube into the glove box, and connected it to a gauge.
This is not something that I'm keeping on the car. I had the tube sitting there so I Decided to check the boost in different gears. I'll get some pics
