Loose side marker lense
Old Feb 14, 2010 | 06:59 AM
sbkim's Avatar
sbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond repute
Hello everyone. I decided to try out different bulbs in my new clear side marker lights. Unfortuately, now the lens is slightly loose. I tried playing with the metal tension spring but to no avail. I doubt that it will fall out but still not as tight as before.
Are there any tricks to getting the lense to snap on tight? I don't think anything is broken but perhaps bad alignment of the tension spring?
Thanks!
Old Feb 14, 2010 | 09:11 AM
gmoney's Avatar
The metal tab that holds it in place is the source of the tension, you should be able to mess with that to hold it more securely, give it another try.
Old Feb 14, 2010 | 05:06 PM
sbkim's Avatar
Thanks gmoney - I think I got it bent to have little more tension. I better stop doing bulb experiments
BTW, your Hoen DLED idea was awesome. Really loving the new city lights.
What is the best way to remove the side marker lights? I followed the directions on Suncoast and simply pulled it out but may be I should use screwdriver to relieve the tension on metal spring before prying it out? Luckily nothing is broken (yet).
Old Feb 14, 2010 | 07:37 PM
dksu's Avatar
dksu has a spectacular aura aboutdksu has a spectacular aura about
Same thing happened to me before. You need to use superglue and afix the base of metal clip to the base of plastic tab. That should fix the problem.
Old Feb 15, 2010 | 07:32 AM
sbkim's Avatar
dksu - I am having a little trouble visualizing where to put the superglue but won't that prevent you from taking it off again? I am sure I am misunderstanding what you wrote...
Old Feb 15, 2010 | 07:34 AM
SuncoastParts's Avatar
SuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond repute
If you need an orange side marker, I have plenty of spares, just pay the shipping!
SuncoastParts.com
Your #1 Source for Genuine Porsche Parts and Accessories on the Web!
Visit us at http://www.SuncoastParts.com
Call us at: 877-923-1700
Email us at: Parts@SuncoastParts.com
Follow us to stay connected:
Join Our Newsletter | Facebook
Old Feb 15, 2010 | 07:45 AM
gmoney's Avatar
Dont use a screwdriver, one slip and you can scrape the paint. I put pressure along the lens to put tension on it then pull press a credit card edge in to pry it out. You can do it with no tools also but easier on the hands using a credit card.
Old Feb 15, 2010 | 07:46 AM
sbkim's Avatar
Suncoast - thank you - but it's my clear lens (purchased from you guys at great price!) that's loose. It's not too bad now after I played with the metal tabs.
PV=nRT.
Sep 9, 2022 06:06 PM
NIKAS
Aug 20, 2019 07:53 PM
Feelgood MD
Mar 24, 2016 09:35 AM
