Sponsored by: Bears Transport
Proto 100-200 kph data
  #91
Old 03-19-2010, 05:04 PM
997John's Avatar
997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all
Originally Posted by milou
Yes the card i used is a Verbatim SDHC class6 4GB, you think this is the reason?
I also need to playa bit with the PBOX since the only thing i know to do is to get the best times
My car has modded VTGs with BRVs, 4,5" I/Cs, exhaust with 100cell cats, ECU/TCU and AEM water/ethanol kit which i don't use at the moment since the ECU needs to be tuned, when i use it my car is slower Actually this is why i was doing the runs, to collect some data and send them to my tuner
Thank you for your kind comments
If you are using too big nozzle it will slow your car, you should try the nozzles and monitor the IAT.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
In my supercharged Truck using Snow performance kit with the power level i have they suggest to use a specified size but i found the one step smaller nozzle worked best on my set it.<o></o>
<o></o>
I asked in another thread about the IAT sensor location so now i'll mount the Nozzle near it and will start with the smallest nozzle and will go up to see what is the best nozzle to go with.<o></o>
<o></o>
  #92
Old 03-19-2010, 05:07 PM
Shotcaller's Avatar
Shotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud ofShotcaller has much to be proud of
Originally Posted by MBailey
I have a ~12.1 s 200-300. I will post graph later...
Awesome!! On what boost?
I know 997John modded Vtg's ran 200-300 in 13.5sec on racegas and 15's on pumpgas and it is tip car
  #93
Old 03-19-2010, 05:26 PM
MBailey's Avatar
It was at 1.5 bar. Here is the graph. I did it at the TX Mile last Oct. I hope to better it in a week...
Old 03-19-2010, 05:28 PM
ttboost's Avatar
My fastest was 13.1 last year at the Mile when I went 195. I was only running 1.3 bar on pump and Meth.
  #95
Old 03-19-2010, 05:38 PM
Shotcaller's Avatar
WOW!! The damn Meth make HUGE DIFFERENCE!!!
  #96
Old 03-19-2010, 05:40 PM
ttboost's Avatar
Yeah, it works for me. I'm spraying 100%. I wanted to turn up the boost but I am maxxed out on my wastgates.
  #97
Old 03-21-2010, 03:39 PM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
Here is a run i did today,
File Type: txt
BEST06.TXT (167 Bytes, 69 views)
  #98
Old 03-21-2010, 08:31 PM
Shotcaller's Avatar
Awesome ran..tip car? pump or racegas?
  #99
Old 03-21-2010, 09:24 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Great time. Get that SD card and you can submit your data for sanctioning on the 996tt forum although I don't think they have 100-200 km/h category. Maybe we can start one here for 997tts, bbywu?
  #100
Old 03-30-2010, 03:58 PM
milou's Avatar
Here is the best 100-200 i did so far, i was running on 100oct pump fuel and ethanol, i need some guidance for how to post a graph of the run
File Type: txt
BEST01.TXT (167 Bytes, 59 views)
  #101
Old 03-30-2010, 04:54 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
5,6 is a very very good time for a cab car...congrats...
  #102
Old 03-30-2010, 05:02 PM
Divexxtreme's Avatar
Why not simply measure your 60-130 times and submit them to the existing list like everyone else does? The existing list contains more 60-130 times (and 100-200 kph as well) of modified cars than any other source on the internet. There is no better place for comparison.
If you really want to compare 100-200 kph to euro cars, you can always pull the times from 60-130 graphs.
  #103
Old 03-30-2010, 05:08 PM
ttboost's Avatar
Exactly. Wouldn't a 5.6 be somewhere in the 7.0-7.2 range 60-130?
  #104
Old 03-30-2010, 05:10 PM
More like a 6.5 or so.
  #105
Old 03-30-2010, 05:12 PM
ttboost's Avatar
Hmmm my 5.99 works out to a 5.24?
Quick Reply: Proto 100-200 kph data
