Help!!!!!!!!!!!!!!!!!!!
Old Apr 2, 2010 | 04:07 PM
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
Today I wanted to use my TT and no battery so no power.
Last week I installed a stupid battery terminal cutoff and then closed the front hood so today I tried to use the car and I remembered this,I tried to connect another bat to open the hood (fuse box port) and nothing.
Please tell me if someone knows if this cars have a manual cable to open the hood.
Someone said that it is necessary to remove the fuse box and there is a emergency cable to open the hood but I checked the manual and they don't mention anything like this.
Please HELP!
Old Apr 2, 2010 | 04:09 PM
Erik@GBox's Avatar
Erik@GBox is a jewel in the roughErik@GBox is a jewel in the roughErik@GBox is a jewel in the roughErik@GBox is a jewel in the rough
Yep it is in the drivers door, as I recall. There is a release that will allow the hood to pop for you.
I hope that this helps,
Erik Johnson
Old Apr 2, 2010 | 04:18 PM
vividracing's Avatar
Luis there is also a metal cable like on a bike on the pass side of the front bumper behind the toe hook cover. I can send you a pic or if you have an iPhone, use the app Knocking Vid and add vividracing. I will show you on the car live.
Old Apr 2, 2010 | 04:24 PM
luiscarlos's Avatar
Thanks VR PM sent...
Old Apr 2, 2010 | 04:46 PM
luiscarlos's Avatar
I just removed the Toe hook cover and I dont see a cable ....
Old Apr 2, 2010 | 04:59 PM
DaveKrek's Avatar
DaveKrek is just really niceDaveKrek is just really niceDaveKrek is just really niceDaveKrek is just really nice
Plug in a battery trickle charger, it will provide enough current to open the hood.
Don't ask how I know this !
Old Apr 2, 2010 | 06:18 PM
imcarnuts's Avatar
imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !
When connecting the battery charger/extra battery to the clip in the fuse box port, use the key remote to open the hood -not the pull lever on the door sill. See #6 on instructions.
File Type: pdf
Old Apr 2, 2010 | 09:20 PM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
you got a rep for that
Old Apr 2, 2010 | 09:29 PM
luiscarlos's Avatar
Thanks for the info,the problem is that the negative bat connector is not making contact and the circuit is open.
I found a exploded view and there is cable in the front near the wheel so I will try this tomorrow.
Old Apr 2, 2010 | 09:40 PM
HansGT2's Avatar
HansGT2 is infamous around these parts
That's correct for a 997; left front wheel well. A technician recently showed it to me. I haven't tried to use it, but he said you have to remove the front inner fender liner.
Old Apr 2, 2010 | 09:57 PM
luiscarlos's Avatar
Thanks I will try tomorrow....
